Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 12-14-2005, 08:15 AM   #1
nickcrowhurst
Profile:
Anyone else get chilly watching TV in the evenings?
Some evenings we'll sit down and watch a DVD Or VHS film through the TV, and my wife has often pointed out that she is feeling cold. The furnace is doing its stuff very efficiently, the thermostat is set to 72 degrees, as usual, the windows are well insulated with accurately cut panels of the silver coated padded material sold to cover car windscreens. The temperature outside in the evening may be between 35 and 55 degrees, so why are we feeling chilly?
After a little thought, I realized what probably many of you doubtless already worked out. The TV, of the traditional cathode ray tube variety, gives out some heat. On an Excella, as in many Airstreams, the usual place for a TV is on the credenza .............just below the wall thermostat! The thermostat is bathed in the warm air rising from the TV, so it shuts the funace off when the temperature by the couch is well below 72 degrees. Some solutions are to turn the thermostat up a couple of degrees, pull the TV forward away from the wall, buy a TV that produces less heat (LCD?), or re-site the thermostat.
We opted to turn the stat up to 74.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 12-14-2005, 09:12 AM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Nick.
Or install a Wave 10 Cat heater on the bulkhead near the door to provide radiant heat My unit had one there at one time and I plan on replacing it when I get done with a few other items.
Aaron
WBCCI #2449 AIR #2495
Old 12-14-2005, 09:28 AM   #3
bhsl8
Eau Claire , Wisconsin
Hey Aaron, just put a sweater on... or use this phenomenon to justify a new LCD flat panel TV. It will take up less space too.
Brouck
Wherever you go... there you are!
bhsl8 is offline   Reply With Quote
Old 12-14-2005, 10:19 AM   #4
wheel interested
wheel interested's Avatar
Profile:  2007 27' Classic FB
Lapeer , Michigan
Images: 118
Heat and Insulation
There are two vents in the front section heating up the thermastat before the rear bedroom is warm enough. We have thought of replacing the duct screens with one that can be adjusted or closed, but don't know where to find them.
I sat and read in the AS last night. It was perhaps in the 20s. Furnace and ceramic heater in the rear, and a sweater for sure, no special window dressing besides the shades and curtains drawn. I noticed that the cold drifts down from the curtains on the windows. Does that insulation work well for you? Do you remove it during the day? I think a sheet of insulation over the skylights and vista views would help as well as wall to wall carpeting. It is also cold around the rear nightstand and walls probably emminating from the outside storage.
What I have also been wondering about is why the furnace has to kick off a burst of cold air each time it cycles on. Is there any way to prevent that from happening, can we add some insulation some where around the ducts? Same with the bathroom air. Yes it warms the room but often the forced air feels cooler than the room air.
Guess I better get a heated cuddlesac or throw.
Carol
Mackinaw City Forums Rally October 3-5
wheel interested is offline   Reply With Quote
Old 12-14-2005, 10:40 AM   #5
Silvertwinky
Silvertwinky's Avatar
Profile:  South Shore , Kentucky
I'm not an expert here but I believe that the furnace requires the air flowing before it will allow the gas to kick on. That would result in a burst of cold air each time it cycles.
Visit our church on the web!
http://www.southshorecog.org/
"A safe camper is a Happy Camper"
Bill & Donna
Air Forums Member # 2360
Silvertwinky is offline   Reply With Quote
Old 12-14-2005, 10:59 AM   #6
bhsl8
I believe the "burst" of cold air is required to open the sail valve allowing propane to enter and begin the combustion process initiated by the pilot or electronic ignition and hence heat. Also, do be careful in closing the front vents etc as this might affect the amount of required air flow reaching the sail vale at the furnace, thus preventing its opening. The result is the fan running with no attendent heat.
Brouck
Old 12-14-2005, 11:14 AM   #7
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
That is it and it happens in a LP fired house furnace too, but just not as noticeable. In the AS you are dealing with a smaller volume.
Wheelinterested,
I use Reflectix in my windows and vista views. Makes a huge difference. I orginally did it for protection from the outside heat in the summer, but it works well in reverse in the winter. FWIW I also used it in the bunk ends of my popup to extend the camping season.
Aaron
Old 12-14-2005, 11:22 AM   #8
wheel interested
Lapeer , Michigan
Images: 118
Guess I will just have to get some long underwear. Actually that's what I wore when we were hit by the two snow storms in Flagstaff and the Grand Canyon this January and except for travel days we were snug enough except for having to shovel "in."
Thanks for the advice and info, I will not block the vents. Aaron has the right idea though. And no drain on the battery! Insulate too. Just maybe I will get a Little Buddy heater if I think I can stand leaving the window open, :-0 while we are awake and emergency type basis. I am a bit "concerned" about using those though.
Aaron, please tell me if during the day you remove the insulation to let the light in or does that defeat the purpose and let all the cold in?
Carol
Old 12-14-2005, 11:59 AM   #9
2airishuman
2airishuman's Avatar
Profile:
hi nick and others
another option (besides kicking up the thermostat) would be a small fan to move air, even between furnace cycles.....why let that hot air the tele produces go to waist....blow it around!
the platinum cat heaters are great since they use so little electricity and can be installed without venting. they are especially nice for the pooch...like being near a warm fire....which it actually is....also ok to use when away from the trailer or watching tv. but be very careful about using them when asleep. while they completely combust the lpg, so there's no CO to kill ya', they do use up the oxygen inside the trailer, so venting is needed for fresh air to breath....cracking a window usually is enough...but there goes the heat.
also keep the cabinet door open since any room air heater will not warm the plumbing like the furnace does...
foil insulation is a great idea for the vistas, skylights, bathroom fan, wrap around windows, and especially the door....
but if it's sub freezing and one places insulation in most of the windows....those windows will freeze! moisture will collect on the insides and because the window/frames are now closer to outdoor temps......iceeeee will form on the inside.
so if using foil.....it should be romoved regularly, and windows checked for ice....
also any trailer zipped up this tight will need regular daily "airing out" or moisture becomes a big problem....
thoughts from someone who's used the airstream for skiing, and fulltimed in sub freezing months...
cheers
2air'
Old 12-14-2005, 12:48 PM   #10
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
The T-stat in my unit is on the rear closet wall of the street side twin beds. Sometimes the pilot would blow out in my old timey NT30, and it would be cold in the morning. So I would light the catalytic heater and turn on a ceramic 1500 watt heater in the bathroom, while I took my morning shower.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 12-14-2005, 12:48 PM   #11
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
It will depend, the bedroom windows usually stay blocked all the time. I love my vista views, I am 6'2" so I can actually see out of them I usually leave at least the kitchen window and two windows in the lounge area unblocked in all but the coldest weather. FWIW I put my reflectix in the window itself, so you have to make a trip outside to install or remove it.
Aaron
Old 12-14-2005, 12:52 PM   #12
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
A good solution is to buy some Reflectix and insulate around the places where cold air can come in.
On my queen bed model, there are a lot of gaps between the nightstand and the plywood bottom of the bed. There is also a small gap at the rear where the plywod doesn't quite match the contour of the body interior. If I lived in a colder climate, I would raise the bed, crawl in there, and staple Reflecticx in that area. The entiire underbed area could easily be insulated from the balance of the trailer.
In my old Scamp, I also put Reflectx all around the interior of the refrigerator cabinet while the refrigerator was removed for service. Kept the heat out in the summer, the heat in in the winter, and actually seemed to improve the coolng of the refrigerator, probably because it increased the thermal currents by keeping the heat contained.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 12-14-2005, 12:55 PM   #13
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Just keep a moving....
remember - when you sit, your metabolism slows, and your body cools off. There's other things to be doing in bed on a cold night to keep warm too.....
Course, you may get a cold shoulder too...
Happy Holidays!
Marc
Old 12-14-2005, 02:42 PM   #14
M&M CAPECOD
M&M CAPECOD's Avatar
Profile:  2002 28' Classic
Cape Cod , USA
Images: 21
Question Electric mattress pad works well for us
We use an electric mattress pad under our regular mattress pad. We turn it on a couple hours before we go to bed and when it's time to slip under the covers it's toasty warm. It gives you more heat at your feet and runs for 10 hours which is perfect because it's turning off when it's time to get up. We have this in our home as well. It only took one cold weekend camping for us to go out and buy one for the trailer. I don't mind if it gets chilly at night when I sleep, I just want it warm when I jump into bed. You can also adjust how warm you want it. I usually have it all the way up when I turn it on and then when I get in I adjust it down. We bought them at Linens 'n Things, used one of those 20% coupons but I've seen them at KMart too, not to much $$.
A quick question, is it true you'll dry out the inside of the trailer some if you run your heat pump?? I like the constant noise of that rather than the on off of the furnace which wakes me up. I know we can set our thermostat on automatic and it'll switch to furnace if the temp drops low enough. I was just wondering which would be a better way to get some of the moisture out of the trailer, the heat pump or the furnace? Is it true that the furnace adds more moisture because propane releases moisture when it's burned?
"A dream becomes a goal when action is taken toward its achievement." -Bo Bennett
WBCCI #9204, Region 1, New England Unit
'02 Grey Lady, 28' not so Classic anymore
'08 GMC Sierra 2500 Duramax/Allison Crew Cab
M&M CAPECOD is offline   Reply With Quote
How to play ebay? maxandgeorgia Off Topic Forum 46 03-10-2007 07:42 PM
Trip to Jackson Center Silvertwinkie On The Road... 31 04-30-2005 10:57 PM
82 28ft Excella turbo-d Bill_in_Texas For Sale & Wanted 12 06-18-2004 02:32 PM
New Airstream Show on Travel Channel Davydd Airstream "In the News" 12 01-05-2004 03:42 PM
clean up your computer john hd Off Topic Forum 2 04-27-2003 11:54 AM
