Old 09-25-2015, 08:39 PM   #1
comprose's Avatar
1999 31' Land Yacht
Kingston , Washington
Antenna Stuck
Typical Winegard antenna. I can raise and lower with ease, but unable to rotate without using a lot of force (afraid of breaking the plastic) and then only about 10-degrees. How can a access this to free it up?
comprose is offline   Reply With Quote
Old 09-26-2015, 01:14 PM   #2
tdmaymac's Avatar
2011 27' FB Flying Cloud
Moschelle , Nova Scotia
I assume you are aware that you have to pull down on the plastic rim in order to rotate it? Otherwise, it sounds like something is causing it to bind up top.
tdmaymac is offline   Reply With Quote
Old 09-26-2015, 10:23 PM   #3
comprose's Avatar
1999 31' Land Yacht
I've taken off the handle and spring, but not able to get much movement trying to rotate the plastic ring, I'll try from the roof to see if I can access the gears. I doubt if the antenna has been rotated in years.
Old 09-27-2015, 09:09 AM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Silicone spray.
Ahab is offline   Reply With Quote
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
Tv antenna stuck! MyNancy1977 Roof 4 03-29-2014 09:01 AM
Stuck Numbers? Mr Jody Hudson Forum Admin, News and Member Account Info 0 07-31-2002 10:13 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
