Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 06-10-2008, 06:28 AM   #1
Beginner
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Antenna Problems
The handle on my antenna is stuck and will not pull down.
Does any one have an exploded view of the antenna or recommendations on how to unstick the beast?
Thank You
Beginner
Beginner is online now   Reply With Quote
Old 06-10-2008, 07:11 AM   #2
jdalrymple
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
The handle does not pull down, to my knowledge. It just turns clockwise or counter-clockwise. This action raises and lowers the mast. The outer ring, closer to the ceiling than the crank, turns the same directions rotates the entire assembly, as the antenna is quite directional and must be pointed at the broadcast tower.
Good Luck!
Jeff, Cindy and the Brittanys:
Remi and Hunter
'81 International 31'CB "Fus-a-lodge"
'03 2500HD Chevy Duramax w/improvments
WBCCI #7026 Air #17054
Old 06-10-2008, 09:57 AM   #3
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
The handle on a Skyliner antenna pushes up towards the ceiling to set the rotation mode and pulls down for raising/lowering. Try a little jiggle as you are pulling. Pull the cover off the gears (as I recall only a couple of screws on top) and check for any binding of the shaft or gears. These need annual attention to ensure proper lubrication. I use a high temperature plumbing grease as I think it held up better in the hot temps on top of the roof. I'll check my Skyliner info when I get home.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 06-10-2008, 10:26 AM   #4
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Rivet Owner's Manual
Thank You
Beginner
Hi Beginner,
Here is a pdf of the owner's manual. Best of luck.
Vaughan
Old 06-10-2008, 10:30 AM   #5
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Here's an exploded view of the Braund Skyliner Antenna and a set of vintage instrustions. Parts are probably still available. If you run into problems, let me know, I can dig some spares out of storage.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-16-2008, 07:57 PM   #6
Beginner
Norfolk , Virginia
Images: 11
Antenna
Thanks to every one for their help.
Armed with I will attempt to unstick and properly service the antenna in the future.
Beginner
Old 06-16-2008, 08:14 PM   #7
rancher Jim
Profile:  1975 25' Tradewind
Albany , Oregon
Thank You
Beginner
I had the same problem, I just put some WD40 on and it came right loose.
rancher Jim
rancher Jim is offline   Reply With Quote
Old 06-25-2008, 08:34 AM   #8
Rodger with a D
Profile:  1970 27' Overlander
Colo Spgs , Colorado
Hola Class
Yesterday afternoon I was going to show the trailer to some friends.
I wanted to "show off" the TV part so I started to raise the antenna. Wit a "pop" and a free spin I can not raise the antenna any longer. Is my 1970 Antenna unit the same as what has been written about here ???
Rodger & Gabby
COS
Rodger with a D is offline   Reply With Quote
Old 06-25-2008, 10:07 PM   #9
Firecop
Firecop's Avatar
Profile:  1978 31' Excella 500
Woodland , Utah
Probably. I was able to get parts to rebuild mine at the local trailer supply. now it works!
Firecop
Firecop is offline   Reply With Quote
Old 07-15-2008, 05:59 PM   #10
willyd
willyd's Avatar
Profile:  1986 31' Sovereign
Melbourne Land Yacht Harbor , Florida
Mine was rusted and the nylon gears were broken, so I decided to just go modern and install the newer batwing type. It is much easier to operate and I am getting a good signal - as compared to nothing before.
willyd is offline   Reply With Quote
Old 07-16-2008, 05:15 AM   #11
Beginner
Norfolk , Virginia
Images: 11
Antenna Update
I copied the manuals supplied here but didn't have the time to mess with the antenna. I met drag'nwagon at the VAC rally in Staunton VA. When he found out I was Beginner, he asked about the antenna.
Seems I had some cockpit problems about operation but I had atleast not damaged anything, however the antenna is stiff and will not lock up which indicates the need for more oil (in the up position) and a new gear.
Thanks for the help. Also (drag'nwagon ) I have secured the replacment parts for the water hose connection from a plumbing supply house in the neighborhood.
Thanks again for all the help.
Still, Beginner
Update on Problems Problems pjude General Motorhome Topics 4 09-04-2007 06:02 AM
CB Antenna wyhjr Electrical - Systems, Generators, Batteries & Solar 14 05-02-2004 01:12 PM
cb antenna norbert Our Community 12 06-19-2003 09:57 PM
TV antenna davidz71 Audio, Video & TV 14 03-14-2003 08:14 PM
Which Antenna ?? Jim Clark Audio, Video & TV 1 07-21-2002 06:32 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
