Old 06-10-2005, 11:08 AM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Antenna Mount
Antenna Mounting Plate
I am trying to remove the mounting plate for our antenna. This is an eletric only, no manual crank inside. The electric does not work and I can find no threads to help repair it. I want to remove all, since the antenna rests on my vent and I will be installing a Fantastic fan. I am down to the plate and a gear. I can move the plate around and around, the gear will not budge. Any ideas?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 06-10-2005, 02:16 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Is there any chance you could post a picture? A thousand words, and so on...
Old 06-12-2005, 04:57 PM   #3
1994 30' Excella
Pictures speak many words
I am posting some pictures of the antenna mount. I can remove the gear on the rod with an allen wrench. The problem is the lower gear. There is no allen screw holding it on. I have tried a crow bar but it does not budge. The only other fasteners I see are rivets on the outside of the plate to the roof. I do not want to drill these out since then my hole to patch will be so much bigger. Plus these rivets were put on from the inside. Once again I have no access to this from the inside. This antenna worked solely on electric.
Chaplain Kent
Old 06-12-2005, 05:05 PM   #4
Well Preserved
1993 21' Sovereign
Kent, it looks like the only way to pull that antenna base off is to scrape off the goo on the outside edge of the rectangular metal piece under the antenna. You should find either screws or rivets holding the base on. Remove them, and the whole thing should lift off the roof. The inner workings don't look like they come off separately.
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
TV Antenna lead fdx753 Audio, Video & TV 14 04-27-2004 08:45 PM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 01:04 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
