Old 10-22-2019, 11:43 AM   #1
1974 Argosy 26
West Des Moines , IA
Antenna leak
So I've completed a strip and prime with Pro-cryl and expected everything to be sealed up with 2 coats of acrylic primer. After heavy rain I found a leak coming right down the antenna crank. 1 can of flex seal later I though the problem was solved. 6 hours of rain on the maiden voyage and we stayed dry, yey! Then a torrential downpour yesterday morning showed I still have water coming in the antenna crank. 74 argosy pic attached, Any suggestions?
natedogg7 is offline   Reply With Quote
Old 10-22-2019, 02:09 PM   #2
1981 31' Excella II
New Market , Alabama
I expect there is an O-ring in there that seals the shaft. Take it apart and find the seal.
Perry
Old 10-22-2019, 05:43 PM   #3
1963 30' Sovereign
Brockville , Ontario
Do you / did you use the crank between when it stayed dry and the latest rainstorm when it leaked?
Maybe it loosened up or vibrated a gap in the flex seal. Try more!
Rob
Strangmoor is offline   Reply With Quote
Old 10-22-2019, 06:19 PM   #4
1974 Argosy 26
Perry
Thank you
Old 10-23-2019, 07:00 AM   #5
1981 31' Excella II
Also there is a plastic weather seal that covers the mechanism. If that is missing it might leak more but I think mine has been gone for years and it does not leak.
Perry
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 08:11 AM
Outdoor HD TV Antenna, ANTOP Flat-panel PL-402VG – 60 Miles Long Range Multi-Dir RV Antenna and installation kit alreardon Airstream Classifieds 0 09-21-2018 10:13 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 08:24 AM
Rooftop Antenna Installation - Spring Mount Cellular Antenna Astw Electronics & Connectivity 4 08-04-2016 09:51 AM
Batwing Antenna Leak Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 10-06-2008 09:08 PM
