Old 02-11-2010, 09:55 PM   #1
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
antenna/cable jack
I have an original antenna. I am going to change the jack to a F type connector. I am wondering if an antenna booster jack does anything for the old anttenna or does it only work on new ones.I dont really even know what they do. I also want to add a cable connection, any thoughts on that. My AS is a '69, will I be burned at the stake if I go through the skin and mount an outside connection?
lahrfarm is offline   Reply With Quote
Old 02-12-2010, 01:46 AM   #2
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Pretty much works the way you'd imagine. The amplifier boosts the antenna signal. In fringe areas, with a analog -> digital converter, the amplifier mean the difference between a signal or none at all.
I submit that an A:B switch mounted on the wall or side of the tv would be the handiest solution - it's what I do. Convert the roof antenna to coax at the antenna connection and snake the coax through with the old banana wire you remove. You can buy replacement amplifiers (for coax instead of twin-lead cable) at RV dealers who have been in business at least 25 years, as well as online.
Good luck!
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 02-12-2010, 01:50 AM   #3
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
I forgot to mention, I have a 25' length of coax attached to the AB switch which is routed through the forward storage cubby. I can make up to most campground CATV connections with that amount of coax. Switch to the cable feed and reset the tv to cable as your source and do a channel search ... and away we go.
wil
AIR 22828
TAC ME-3
Latitude: 44.894663
Jack for TV antenna outlet?? Help !!!! goldenlily Audio, Video & TV 4 10-03-2010 08:02 PM
exterior cable jack pjude Classic Motorhomes 3 05-02-2009 10:35 AM
Antenna Cable Threading -Help! carl johnson Audio, Video & TV 3 07-11-2008 04:44 PM
Bad Cable from Power Amp to Winegard Roof Antenna tntom Audio, Video & TV 3 06-24-2008 09:09 PM
Need help with a TV antenna cable... replacement Northway@mag Audio, Video & TV 7 07-16-2007 07:23 PM
