Old 08-17-2010, 09:58 AM   #15
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Sorry, I should have been more clear. Because of the age the AS in the first post, I did assume this installation was the power supply/head mounted amp setup. I agree there are all manor of options out there.
2air, thanks. I need my button pushed now and then.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-18-2010, 12:08 PM   #16
Ottawa , ON
This (permanent, non-mobile) antenna claims 100 mile range.
Of course, as Mark Twain once said, there are lies, damn lies, and statistics, so Caveat Emptor, which means never let your cave get empty.
Seriously, from the OP's original post, I'm not sure he's talking about a 'tenna for his 'Stream, look at his stated home city!
Git them poles up there, buy the bestest deevice you can get your hands on, then AMPlify it, and don't fergit to use the fancy dollar-a-foot downlead! It DUZ all make a HOOJ difference...
Old 08-18-2010, 12:22 PM   #17
1986 25' Sovereign
Plant City , Florida
Sorry to hijack... but I have the old style antenna with the booster at the wall plate. Every time the bathroom fan is turned on i lose signal. I know this I due to interference. Does anyone know the cable from the antenna to the booster can easily be repleaced or should i just buy a new antenna?
ck21084 is offline   Reply With Quote
Old 10-07-2014, 01:38 PM   #18
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My Sensar antenna fits in a metal cradle on the roof of my 2008 Classic 25fb. Does anyone know if the Wingman addon will clear the metal cradle?
Kelvin
Old 10-07-2014, 01:50 PM   #19
dznf0g's Avatar
Oswego , Illinois
Kelvin
Mine does
-Rich-
Old 10-07-2014, 01:51 PM   #20
2010 25' FB Flying Cloud
Davenport , Iowa
Yes, it will, but also look at the NEW Wineguard antenna. It looks like "home plate" and is multidirectional and works well with HD. The replacement head costs about $50.00.
mike
Airtandem is online now   Reply With Quote
Old 10-07-2014, 04:12 PM   #21
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I just replaced my Sensar with the new Razar, very easy job. The only "complication" is cutting the end of the cable so that the cable can be pulled thru the pole. You then have to put a new cable connection on the end so you attach it to the new Razar. The removal and installation is very easy. I also have the Winegard SendarPro inside the trailer. I like seeing the strength when rotating the antenna. Again very easy replacement.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 10-07-2014, 06:07 PM   #22
Ottawa , ON
There is a device listed as the Rayzar.
But this unit is listed as an internal antenna. Is it also used on the external of TTs?
Old 10-07-2014, 06:29 PM   #23
1973 25' Tradewind
Augusta , Georgia
It's jobs like these that make you value you friend that is a cable guy...
DGJackson is offline   Reply With Quote
Old 10-07-2014, 09:51 PM   #24
extiger's Avatar
2011 30' Classic
Kingwood , Texas
Oops on the spelling. It is Rayzar and yes they make an RV version. On sale right now at Camping World. It come with a new shorter mast. Take old mast off and put on new. It helps to have either a cable guy friend or Rg6 compression fitting tool.
2011 30' Classic
ProPride Hitch
Old 10-08-2014, 07:36 AM   #25
Davenport , Iowa
?? on my antenna, there were two "poles" one containing the coax and the other empty. I unscrewed the coax from the head, removed the pole not containing the coax, fastened the NEW Rayzar to the remaining pole, screwed the coax to the Rayzar and was done. Less than 15 minutes. Works great. I had purchased the amp head only, About $50.00 there is another version that is more complete for $150.
mike
Old 10-08-2014, 08:27 AM   #26
KJRitchie's Avatar
2008 25' Classic
Mike, did you have the Wingman on your old Sensar beford the Rayzar?
What is you opinion about the reception.
Back to my previous question, will the Rayzar head rest on the aluminum cradle on the roof? I could add stick on rubber bumpers on the high points of the cradle.
Kelvin
What is it: Antenna and? bmklawt Audio, Video & TV 3 12-18-2008 11:32 PM
FM antenna Phil Gobie Electrical - Systems, Generators, Batteries & Solar 6 12-24-2006 11:28 AM
Antenna JLD Electrical - Systems, Generators, Batteries & Solar 13 08-31-2006 08:41 PM
Antenna silverlassie Audio, Video & TV 19 05-01-2004 01:02 PM
Which Antenna ?? Jim Clark Audio, Video & TV 1 07-21-2002 06:32 PM
