Old 02-26-2007, 04:32 PM   #1
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
AM Antenna Again
My 71 Overlander has the OEM radio antenna with that round rubber mount. Has anyone replaced it with an aftermarket antenna? If so where did you get it? I see universal mounts for about $10 in the auto supply stores but I don't know if it will work.
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 02-26-2007, 07:01 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
fishing
I have not replaced mine but want to. I am more concerned with fishing the new antenna cable through the coach than the antenna itself. I also notice that while my cars pick up some stations fine the radios in my streams do not. The radios are pretty good aftermarket so I suspect there is a difference in the receptivity of the old factory antennae.
Old 02-26-2007, 08:06 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Also a 71 Overlander
The antenna on our 71 looks original also. Chrome ball with a spring lead to the antenna. Replaced the old original radio with a cheap Dual brand. In our case the A/S gets reception that astounds me - much better than the Durango sitting right next to it - both am/fm.
Maybe the antenna leads just need a good cleaning at both ends? Think I have the Service Manual diagram of the connections/install/removal if you think it will help.
Old 02-27-2007, 06:36 AM   #4
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
AM/FM antenna.
Hi niftypkg; The one antenna we found to work just about anywhere is Shakespere Model 4351. Price about $65.00. It is 3' antenna with 1"-14 thread nylon ferrule, and it would require Sea Dog SDG3296001 swivel mount.
One better yet is Shakespere SHA5420XT which is a 4' tall, and will fit the same Sea Dog mount. They are available through any Marine dealers. Price for 5420XT about $110.00. Above SS mount about $47.00. Thanks, "Boatdoc".
boatdoc is offline   Reply With Quote
Old 02-27-2007, 08:27 AM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
The problem on my antenae on my 71 and 73 is the base mount is dried out. My antennea no longer point up, but down. I also can't unscrew the mounting bolts without them spinning so I guess I will have to cut them. Suggestions?
Old 02-27-2007, 10:18 AM   #6
boatdoc's Avatar
1973 Argosy 26
Hi Marshall; Even if you cut them, you will need to bolt it back in. You might as well remove the inner skin just enough to get to it and make worth while repair. Thanks, "Boatdoc"
Old 02-27-2007, 11:29 AM   #7
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Our Overlander has a bracket mounted on the roof, between the air conditioner and fridge vent. That way you don't have to remove interior skin, and the antenna is more centered, leading to more uniform reception.
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 11:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 02:30 PM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 02:04 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
