Old 04-23-2012, 07:44 PM   #1
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Adding second TV
Has anyone added a TV to the bedroom area of Flying Cloud? If so what mounting bracket did you use? I called Jackson Center and they want $185.00 for just the bracket!!! Wal-Mart has one but it only uses 2 screws, that doesn't seem strong enough to me to handle the vibrations of traveling down the road.
Gary
Castaway is offline   Reply With Quote
Old 04-23-2012, 08:33 PM   #2
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
I bought mine at Walmart I think it was about 50.00 . I was able to get to the back of the area were I was going to mount the TV andi put a bracket on the back side about 1 1/2 inch by 4 inch long with holes Thur it and put the bolts into the wall through the wall mount and the bracket on the other side and tightened down. Very strong now.
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 04-23-2012, 08:48 PM   #3
dznf0g's Avatar
Oswego , Illinois
I got a Rocketfish at one of the big boxes for less than $50. I also dismantled the wall which contains the pocket door and backplated the thin wall. I then padded the backplate so the door wouldn't get scratched.
Seems fine running down the road for about 1 1/2 years.
-Rich-
Old 04-23-2012, 09:11 PM   #4
steverino's Avatar
2018 30' Classic
Ivins , Utah
I went to the same company that sourced the TV mount in the living area: moview.com. But instead of the double-swing arm I got the single swing. It has the same latching mechanism.
Moview: WSSL Single Swing Arm Mount w/ Lock
Just make sure you order the one that swings out to the left - they are not reversible. I mounted it the same way the first one is mounted - via screws directly to the bulkhead separating the shower from the bedroom.
steverino is offline   Reply With Quote
Old 04-23-2012, 10:18 PM   #5
Castaway's Avatar
Celina , Ohio
After my post I went to Amazon and found one for $35.00.
Gary
Old 05-09-2012, 03:15 PM   #6
btowntincan's Avatar
Mercer Island , Washington
Which brand did you get
any info on the installation? Did you use a backing plate or not? Thinking of putting one in the same area in my '06.
btowntincan is offline   Reply With Quote
Old 05-09-2012, 03:37 PM   #7
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Thanks for the link. I just pulled the CRT tv out of the bedroom "cabinet" and will pull the cabinet off the wall & ceiling, then mount a flat panel using the Moview. I used the AS backing plate in the living area when I changed that one, used the slots for a new Velcro strap to hold it in place while driving, and a double swing arm from Costco, and wish I had seen the double swing arm that latches. I have some metal-on-metal contact when stored that will cause a long term failure, right now there's some cork gasket material as a "cushion."
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
