Old 08-18-2010, 03:26 PM   #1
1963 22' Safari
sherman oaks , California
62 Safari television plug
of course all the plugs are AC but noticed one that says TV. Is that a 12v television plug in? But it's a 2 prong plug in?
Any help would be appreciated...I'm just starting the exploration process of installing a television
mmenchel is offline   Reply With Quote
Old 08-18-2010, 03:51 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I think it is for the antenna. My 68 has a similar plug and it is the old 300 ohm ribbon cable from the antenna.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-18-2010, 05:28 PM   #3
walter1's Avatar
1964 22' Safari
Foresthill , California
What he said
He's right.
Old 300 ohm TV antenna wire 2 prong receptacle. Other end should go to TV antenna connection. I expect not too much functional use with today’s digital tvs/converters.
If you decide to remove/replace it permanently please let me know. I am looking for one of those wall receptacles in good condition.
walter1 is offline   Reply With Quote
Old 08-18-2010, 06:07 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
And I am looking for the outside white piece as the Phoenix heat and relentless sunshine are destroying mine at an alarming rate.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Television for 19' Safari Davadar Audio, Video & TV 8 05-02-2010 07:26 AM
Second Television in 25 Safari SE FB Hyperion Audio, Video & TV 5 11-17-2008 09:25 AM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
Plug for '61 Safari Rick Dotson Electrical - Systems, Generators, Batteries & Solar 2 04-27-2004 08:46 AM
My television antenna plug on 77 international wayne.yl Audio, Video & TV 6 12-12-2003 03:47 PM
