Old 05-29-2015, 11:30 AM   #1
bandboss's Avatar
2005 31' Classic
Placentia , So. Calif.
12v power to TV
Our 2005 Classic 31 has factory-installed TV with the CD and DVD players in the forward cabinet above the gaucho. While vacuuming the dust and schmutz out of the fridge cabinet, I noticed that the TV was powered by a 120-12v wall wart in the cabinet. Is there any way to get rid of the adapter and just power the TV from the 12v system of the trailer? This way, we could watch the tube while not connected to shore power. I realize it could be a pretty hefty draw, but we don't spend that much time watching TV.
BTW, the CD and DVD players are already 12v-powered.
Dan
2004 8.1L GMC Yukon XL pulling 2005 Classic 31'
bandboss is offline   Reply With Quote
Old 05-29-2015, 12:13 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Easy, remove the converter and attach a 12 volt plug. My 22 inch came with both a 120 and a 12 cord.
MICHAEL
Old 05-29-2015, 12:44 PM   #3
bandboss's Avatar
2005 31' Classic
12v power to TV
Is polarity an issue?
Dan
Old 05-29-2015, 01:02 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes, polarity is important, but easy to figure out.
2012 Dodge Durango Hemi/AWD
Old 05-29-2015, 01:06 PM   #5
bandboss's Avatar
2005 31' Classic
Is it time to break out the multimeter?
Dan
Old 05-29-2015, 02:21 PM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Typically, a 12 volt plug and outlet have +12 volts on the center conductor, and ground/return is the outside conductor. The power supply should show how the 12 volt plug is wired, and the TV might show how the input is wired.
You can check the output of the power supply with your multi-meter to verify.
Old 05-30-2015, 07:56 PM   #7
Mission Viejo , California
I installed a 12 volt tv and blu-ray player in my sob and found that when plugged in to shore power or on the generator, the dc voltage went as high as 14 volts and wasn't "clean". So although it worked great when on battery only, it wasn't watchable when 110 volts were present. Plus it kept blowing fuses.
So I got a 12 volt dc regulator and wired it inline. Now I have a clean 12.3 volts dc no matter what and the tv takes so little power we never run down the batteries.
Just something to consider...
Bill Lynch is offline   Reply With Quote
12v
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 04:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 11:58 AM
No 12V Coach Power swebster Airstream Motorhome Forums 5 08-03-2004 04:07 PM
12V power loss sladew Electrical - Systems, Generators, Batteries & Solar 2 08-05-2003 05:47 PM
No 12v Power wcdelorme Electrical - Systems, Generators, Batteries & Solar 13 05-11-2003 10:53 AM
