Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 04-05-2012, 07:17 PM   #1
rbr
rbr's Avatar
2004 28' Safari
Semora , North Carolina
12V feed for TV
Hi,all
I have a 2004 28' Safari and am replacing the old tv mounted to the W/C bulkhead w. a new Naxa 23" 12 v set. I want to run the new set on 12v but there does not seem to be a 12v feed in the curbside tambour where the antenne and av wiring comes out, only a 110 outlet. Should there be 12v available in this location? Alternatively, could I safely tap the hot wire for the light above the dinette? The tv draws 45w and the lites are replaced w. LED. FWIW, the old 12v tv was plugged into 110.
Bruce Robillard
Danville, Va.
rbr is offline   Reply With Quote
Old 04-07-2012, 07:54 PM   #2
rbr
rbr's Avatar
2004 28' Safari
Resolution
Installed the tv, tapped the dinette light circuit which has a 10g wire feeding 2 bulbs, easily will carry the tv which feeds with a 18g... the picture is gorgeous with the OE antenna, in an area with lousy reception.
Bruce Robillard
Danville, Va.
12v
Type K Copper for LPG SilverHoot LP Gas, Piping, Tanks & Regulators 12 07-12-2012 05:44 AM
FOD Rally for 2012 blmitch5 Friends of Dorothy 391 06-22-2012 06:20 AM
Suggestions for South Carolina RV parks on beach? Lothlorian Airstream Lifestyle 25 04-14-2012 07:36 AM
12V feed for TV rbr Audio, Video & TV 1 04-07-2012 07:54 PM
Suburban furnace model for 28'? inTransit Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-05-2012 08:28 PM
