Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 07-02-2008, 08:25 PM   #1
tlavergne
tlavergne's Avatar
Profile:  1978 29' Ambassador
Kenton , Ohio
12 volt receptacle
I recently installed a Winegard Batwing antenna to my 1978 Ambassador. It came with a 12 volt receptacle located in the wall plate that feeds the Coax cable. My problem is that none of my 12 plugs will fit into the receptacle...they are too big. My guess is that there is both US and European sizes of the receptacles and I got the European one. Anyone else have this problem? Are there adapters made to step up the size? Just curious if anybody else has run into this problem and has any solutions other than wiring in a new receptacle.
Tom
tlavergne is offline   Reply With Quote
Old 07-02-2008, 08:27 PM   #2
tlavergne
tlavergne's Avatar
Kenton , Ohio
Tom
I meant 12 volt plugs.
Tom
Old 07-02-2008, 08:35 PM   #3
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Check this thread out...there is some discussion of some 12 v receptacles not being the right size...I haven't checked ours yet, but I intend to...
inverter plug
TB & Greg...and The Girls—Annie & Sadie
Members of the Four Corners Unit
NEW! Visit AZBambi Décors: http://www.tbrich.com/azbambi/decors.html
Visit our Travel Log: http://www.tbrich.com/azbambi/trips.html
Old 07-02-2008, 09:13 PM   #4
tlavergne
tlavergne's Avatar
Kenton , Ohio
I looked this up on Wikipedia and found that indeed there are two sizes. This is what I found
"12 volt cigar lighter receptacle and plug, size A
  • Receptacle inside diameter: 20.93 mm to 21.01 mm (median 20.97 mm)
  • Plug body diameter: 20.73 mm to 20.88 mm (median 20.805 mm)
  • Most often used in American automobiles.
12 volt cigar lighter receptacle and plug, size B
  • Receptacle inside diameter: 21.41 mm to 21.51 mm (median 21.455 mm)
  • Plug body diameter: 21.13 mm to 21.33 mm (median 21.18 mm)
  • Most often used in European automobiles, and sometimes as a second socket in American automobiles expressly for DC power connections."
That answers the question of why two sizes. I am still trying to figure out if an adapter is made or not. The "Size B" receptacles are useless the way they are.
Tom
12V Receptacle henw Batteries, Univolts, Converters & Inverters 15 06-01-2007 09:12 AM
Electrical Help - Splitting a receptacle COArgosy78 Electrical - Systems, Generators, Batteries & Solar 4 07-03-2005 03:57 PM
Antenna/TV receptacle Al1 All Argosy Trailers 11 07-06-2004 12:20 PM
Electrical receptacle in storage compartment Kistler Our Community 4 06-27-2003 07:18 PM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 07:19 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
