Old 05-16-2019, 06:33 AM   #21
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I mounted my soundbar by fabricating two 1.5" strips of Aluminum(think Airstream decor). The aluminum was a stock item at Lowe's. I drilled holes in the TV mounting bracket where it attaches to the TV. The strips of aluminum then bolt to the soundbar mountings and the TV bracket. I cut the length so that the soundbar is right under the TV and it moves with the TV. This idea only works for those TV's that are on a movable mount.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-16-2019, 07:57 AM   #22
2019 25' International
Providence , Rhode Island
Here is the finished install, what is not shown is an Amazon Echo Dot added on top of the cable box after I took these images. But ultimately it is finished and now all sources produce 1080p to the TV's via HDMI.
ID:	340873   Click image for larger version
ID:	340875   Click image for larger version
ID:	340877   Click image for larger version
kittmaster is offline   Reply With Quote
Old 05-16-2019, 09:34 PM   #23
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
By the way, Samsung announced that the 5 series TVs (of which the 32 is the smallest) will be upgradable to built in Apple TV. That saves having an external Apple TV hockey puck knocking around.
daleyocum is online now   Reply With Quote
Old 05-17-2019, 12:03 AM   #24
daleyocum's Avatar
Portland , Oregon
Larry
That sounds like a great idea. What swing arm did you end up using?
1973 & 1976 Windows Parts & 80's Door-Negotiable tbashin Airstream Classifieds 0 01-01-2018 08:22 PM
Carefree Roadside & Rear Window Awning Arms & Rollers For 1976 31' Airstream Sovereign mrnos44 Airstream Classifieds 0 08-23-2016 07:08 PM
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
