Old 10-08-2012, 12:10 AM   #1
1976 31' Sovereign
Felton , California
Water pump - necessary?
I have a new to me 1976 Sovereign. The water pump has had all the wires cut to it, and is in pretty rough shape.. this AS will be stationary (the RV toilet was already replaced with a regular one, too hard to move out of my property, etc - itll be a guest house). Is this pump necessary?
My house water is from a spring, which goes into a tank, and is pumped to my house/pressurized through it with a pump. The AS will be hooked up to water from my house, after that pump. So, water should be good with pressure, yes?
Thanks all
FeltonAS is offline   Reply With Quote
Old 10-08-2012, 05:27 AM   #2
2007 23' International CCD
Charlotte , North Carolina
No to the first question and yes to the second. If you are not moving the trailer and you have house or city pressure then you do not need the trailers water pump. The trailers water pump is only for the on board fresh water tank.
You are good to go.
dboehmer is offline   Reply With Quote
Old 10-08-2012, 07:16 AM   #3
1977 Argosy 24
Milltown , Wisconsin
If you remove the pump, you will have to plug the pump output water line. If you don't it will leak water all over the trailer when hooked to the city water connection.
ventport is offline   Reply With Quote
Old 10-12-2012, 09:42 AM   #4
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
second the motion from ventport. Plug the hose that goes to the outlet port of the pump, don't just put a splice on it otherwise you will have constant water going to the fresh water tank.
Also get a GOOD Water Pressure Regulator, City water pressure raises a lot and is a know fact.
Any pics of the guest house?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
