Old 07-16-2015, 02:12 PM   #1
Tincampers's Avatar
Sneedville , Tennessee
Water Heater will not light on propane
2014 FC. The water heater will not light on propane unless I go outside and open the cover a bit. Then, it will fire right off. I have to leave the door open all the time that I need hot water or it will go into lockout mode (red light on).
Any ideas?
Tincampers is offline   Reply With Quote
Old 07-16-2015, 02:28 PM   #2
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Had same problem and it was intermittent. There was a Gasket on the bottom edge of door that the service rep scraped off of mine , and it's has worked ok since. (that was in Jan.)
knunut is offline   Reply With Quote
Old 07-16-2015, 03:12 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Are you in Mobile.... or are you at higher elevation than where it worked before...?
I would remove the burner tube and clean it out...also, do you have a 'bug screen' over the vent? try to run a soft wire down the vent to see if you can knock loose any bug nests... let us know what you find.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-16-2015, 04:53 PM   #4
Tincampers's Avatar
Higher elevations. We no longer live in Mobile. We never had the need to try it out on propane until we started boondocking.
Old 07-16-2015, 05:05 PM   #5
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I have the same thing happening. We are leaving tomorrow for a quick weekend getaway and will check for gasket issue. THANKS
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 07-16-2015, 05:17 PM   #6
coloradopete
coloradopete's Avatar
1988 25' Excella
Montrose , Colorado
I live in Colorado, high elevation. There is an air flow control tube located on the outside of the main fire tube. This tube slides back and forth over the fire tube and it has an opening in it to allow more or less air to flow with the gas. The tube is held in place with a small screw. Loosen this screw and either increase the air flow (higher elevations) or reduce the air flow (lower elevations). A little practice in adjustment will tell you when the adjustment is correct.
coloradopete is offline   Reply With Quote
Old 07-16-2015, 06:15 PM   #7
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Open the cover, there is a black wire that connects to the igniter. The insulator wore down on mine and was shorting aginst the cover!!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-16-2015, 06:17 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Does it 'light' then expire?
Channing
WBCCI# 30676
Old 07-16-2015, 06:19 PM   #9
Gsmblue's Avatar
Bend , Oregon
Does it light with the cover open?
Old 07-16-2015, 06:32 PM   #10
Tincampers's Avatar
With the cover closed, it tries to light 3 times and then goes to lockout. With the cover open it lights on the first try.
I checked the black wire and it is fine but I went ahead and placed it so that the cover doesn't contact the wire.
I will check that airflow adjustment, that sounds very likely to be the issue.
Old 07-17-2015, 11:43 AM   #11
1996 25' Excella
Tillsonburg , Ontario
Adjust the airflow so there is just a hint of yellow at the tips. The flame should be relatively quiet. If it warbles there is too much air. That can make for a harder ignition, but that doesn't seem to be your problem. I would also check the location of the spark and probe that detects the flame. I wonder if it lights with the door open because there is a bit more turbulence with the door open that agitates and moves the gas flow into the spark.
JCW
JCWDCW is offline   Reply With Quote
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Water heater - pilot light wont light africaroots LP Gas, Piping, Tanks & Regulators 18 08-06-2012 03:14 PM
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Hot Water Heater pilot light will not stay on Patrickf Water Heaters, Filters & Pumps 5 03-22-2010 11:00 AM
Pilot light works, but heater does not seem to light FLYNCLD Water Heaters, Filters & Pumps 6 06-13-2009 08:57 AM
