07-16-2015, 02:12 PM
Sneedville
, Tennessee
Water Heater will not light on propane
2014 FC. The water heater will not light on propane unless I go outside and open the cover a bit. Then, it will fire right off. I have to leave the door open all the time that I need hot water or it will go into lockout mode (red light on).
Any ideas?
07-16-2015, 02:28 PM
2023 16' Basecamp
Chgo. N.W. Burb's
Had same problem and it was intermittent. There was a Gasket on the bottom edge of door that the service rep scraped off of mine , and it's has worked ok since. (that was in Jan.)
07-16-2015, 03:12 PM
1999 34' Excella
Hillsboro
Are you in Mobile.... or are you at higher elevation than where it worked before...?
I would remove the burner tube and clean it out...also, do you have a 'bug screen' over the vent? try to run a soft wire down the vent to see if you can knock loose any bug nests... let us know what you find.
Peace and Blessings..
Channing
WBCCI# 30676
07-16-2015, 04:53 PM
Sneedville
, Tennessee
Higher elevations. We no longer live in Mobile. We never had the need to try it out on propane until we started boondocking.
07-16-2015, 05:05 PM
2015 25' FB Flying Cloud
Manassas
, Virginia
I have the same thing happening. We are leaving tomorrow for a quick weekend getaway and will check for gasket issue. THANKS
07-16-2015, 05:17 PM
coloradopete
1988 25' Excella
Montrose
I live in Colorado, high elevation. There is an air flow control tube located on the outside of the main fire tube. This tube slides back and forth over the fire tube and it has an opening in it to allow more or less air to flow with the gas. The tube is held in place with a small screw. Loosen this screw and either increase the air flow (higher elevations) or reduce the air flow (lower elevations). A little practice in adjustment will tell you when the adjustment is correct.
07-16-2015, 06:15 PM
2015 25' Flying Cloud
Bend
, Oregon
Open the cover, there is a black wire that connects to the igniter. The insulator wore down on mine and was shorting aginst the cover!!
07-16-2015, 06:17 PM
1999 34' Excella
Hillsboro
Does it 'light' then expire?
Channing
WBCCI# 30676
07-16-2015, 06:19 PM
Bend
, Oregon
Does it light with the cover open?
07-16-2015, 06:32 PM
Sneedville
, Tennessee
With the cover closed, it tries to light 3 times and then goes to lockout. With the cover open it lights on the first try.
I checked the black wire and it is fine but I went ahead and placed it so that the cover doesn't contact the wire.
I will check that airflow adjustment, that sounds very likely to be the issue.
07-17-2015, 11:43 AM
2012 23' FB International
Woodstock
, Ontario
Adjust the airflow so there is just a hint of yellow at the tips. The flame should be relatively quiet. If it warbles there is too much air. That can make for a harder ignition, but that doesn't seem to be your problem. I would also check the location of the spark and probe that detects the flame. I wonder if it lights with the door open because there is a bit more turbulence with the door open that agitates and moves the gas flow into the spark.
JCW
