Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 10-16-2007, 06:31 AM   #1
SteveH
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
Water Heater Pilot Won't Light
Anyone have any ideas on how to fix this? As the title says, the water heater pilot won't light, but if I hold the flame in there long enough to heat the thermocouple, the main burner will light and burn... so the burner is good, the thermocouple is good, and the valve is good (at least on the main burner portion).
Your thoughts?
SteveH is online now   Reply With Quote
Old 10-16-2007, 08:50 AM   #2
Moonshot
The Painted Pig
Moonshot's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
East Central , Alabama
Images: 14
Mine will not light...unless I turn on a stovetop burner and let the gas flow through that for a minute. Then, I struggle but it lights eventually.
Have you tried that yet?
Scott
Moonshot is offline   Reply With Quote
Old 10-16-2007, 08:51 AM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Steve,
Sounds like the spacing between the pilot and the t/couple might be too large. Check your manual for the exact gap, but they usually are at 1/8". If the pilot is not providing enough heat for the t/couple to maintain the pilot, you might have a partial blockage in the gas burner tube also, or a partially defective gas valve.
Have you been holding the valve down after lighting the pilot for at least 30 seconds to allow for proper t/couple heating?
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 10-16-2007, 10:18 AM   #4
SteveH
SteveH's Avatar
San Antonio , Texas
Thanks for y'alls input, but please read the symtoms again....the pilot light will not light. The main burner works OK after I hold the propane match on the thermocouple long enough for it to heat up, but the pilot light never lights.
Old 10-16-2007, 04:30 PM   #5
lewster
Commercial Vendor
lewster's Avatar
Sorry Steve,
I thought that the pilot would not stay lit. I would then check the gas valve, and disconnect the pilot LP feed tube from the valve and burner head and blow it out with a heavy shot of compressed air. It might be blocked, thus not allowing the LP to flow from the valve to thru the tube to be ignited. If it still wont work, I would then replace the pilot tube AND the gas valve, as the pioot function on the control knob may not be functioning, and the gas valves are not field serviceable.
Hope this helps!
AIR # 10325
Old 10-16-2007, 05:55 PM   #6
beckybillrae
beckybillrae's Avatar
Profile:  1986 31' Sovereign
Schererville , Indiana
When I replaced my thermocouple it wouldn't stay lit either. Andy from Inland told me to tighten it "really hard". That was the problem. Not in tight enough (and I thought I tightened it hard enough the first time). I'd try that before anything. It was an easy fix!
Becky
beckybillrae is offline   Reply With Quote
Old 10-16-2007, 06:01 PM   #7
beckybillrae
Sorry, read your post wrong----whatever Lew says, that's the ticket!
Becky
Old 10-16-2007, 06:11 PM   #8
SteveH
SteveH's Avatar
San Antonio , Texas
Originally Posted by lewster
Sorry Steve,
Hope this helps!
Thanks Lew, I'll disassemble it tomorrow and see if there is an obstuction. If not, I guess it will be a trip to the RV store for parts.
Steve
Old 10-19-2007, 12:41 PM   #9
SteveH
SteveH's Avatar
San Antonio , Texas
Just an Update
Lew,
You were right...the pilot light feed tube orifice was choked up. When I took it off, I couldn't even see the orifice it was so small, and maybe because it was choked up with whatever. I blew it out, reverse flow, and then I could see the tiny orifice and could even blow thru it with my mouth and feel a small flow.
Result is, it works fine now. Thanks again for your help.
Steve
Old 10-19-2007, 12:51 PM   #10
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Lew's the man!
Richard
Charter Member Four Corners Unit
Old 10-19-2007, 06:50 PM   #11
lewster
Commercial Vendor
lewster's Avatar
Awe shucks............. Thanks gang!
AIR # 10325
Old 10-20-2007, 06:50 AM   #12
jonybgood
Profile:  1970 27' Overlander
Amarillo , Texas
glad he got that fixed, also everybody keep an eye out for cob-web accumulation that can plug pipes and outlets too...
jonybgood is offline   Reply With Quote
[IMG] code is Off
Water Heater Pilot APB Water Heaters, Filters & Pumps 10 06-08-2007 02:35 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater pilot light help? PolisherGuy Water Heaters, Filters & Pumps 5 05-13-2006 08:41 AM
pilot light on water heater kthomson Water Heaters, Filters & Pumps 2 12-30-2003 08:38 PM
Water heater pilot issues? Marko69AS Water Heaters, Filters & Pumps 8 07-14-2003 09:46 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
