Old 03-26-2011, 06:49 AM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Stove & furnace for Bambi II
I need to get a stove & furnace for the Bambi II. I can get ahold of both in vintage (from a Caravel) that will fit. Owner says both are in good working order. However, would you go with the big furnace & stove top if you were redoing the whole thing, or would you get a new sleek cooktop that takes up less room & skip the furnace & get the catalytic heater that slaps on the side of the cabinet and have the space in the big cabinet for storage? Don't care if I keep it vintage on the inside, since everything will be new to it!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-26-2011, 07:29 AM   #2
Ottawa , ON
If I was replacing an old furnace (which I plan on doing this year), it would not be with another old one, Becky. That is an item that has the potential of causing life-endangering problems, and I'm not going to fool around.
Not only can it cause a fire if the combustion chamber leaks, but if the LP gas leaks, it can be a silent killer.
Sorry to sound so morbid, but I don't find anything charming in an old furnace at all...
Old 03-26-2011, 12:14 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Good advise, Aage. I think I'll just stick with the new idea.
Becky
1964 Bambi II
1988 Avion 32S
Old 03-26-2011, 12:34 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Becky, with counter space at such a premium in that trailer, I think I'd go with a modern 2 burner cooktop.
I'd also take advantage of the chance to switch to an on-demand fresh water system as well, if yours is still one of the pressurized tank types.
Old 03-26-2011, 08:23 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
I got the original hot water heater tank out today. What a BEAST! It was huge! I had to pound the top in order to get it out. My sawzall came in handy with that thing. I think I will go with a two burner stove. I've seen some that are pretty compact. I can't ever recall using more than two burners at a time in my big trailer. I'll probably get a 6 gallon tank hot water heater. That's what I have in my Sovereign. The Bambi II probably will only have a 15 gallon grey tank, so what's the use of a huge water heater? The on demands are pretty pricey. I would consider it more for a trailer that we would actually shower in more often (with a larger grey tank). Too bad I can't switch the two out!
Becky
1964 Bambi II
1988 Avion 32S
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Look inside your furnace pgr32e Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-17-2011 10:37 AM
Furnace Noise azflycaster Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-06-2011 11:36 AM
A handy schematic snapshot from my furnace - 1970 Sovereign ranger_rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 02-18-2011 10:34 PM
