Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 10-04-2004, 08:15 PM   #1
John W
Profile:
Question Start up Appliances
I have been gifted a 1977 31' International. It has been sitting for 5 years. I have just replaced the valves and filled the propane tanks. What is the start up procedure for the appliances? Is there a main propane valve?
John W is offline   Reply With Quote
Old 10-05-2004, 02:56 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Welcome to the Forums!
There is no main propane valve other than the ones on the tanks themselves. Each appliance, however, will more than likely have it's own shutoff valve.
The procedure I followed when I was in situation similar to yours was to light the cooktop first, and let it run for a minute or so. This accomplishes two things - It fills a lot of the gas line rather quickly (if it was empty), and it provides fast gratification that your LPG system works.
Everything else might take a little while to light since the amount of gas needed to sustain a pilot light moves rather slowly down the line.
Don't tell anyone, but I cheated when it came time to light the water heater pilot light. The gas lines had been open for other repairs for some time, meaning there was absolutely no gas in the lines, and the water heater is more than 20 feet away from the tanks . I turned the water heater to "ON" instead of "Pilot", and used my propane torch on a low setting to bathe the thermocouple in heat. As soon as it was warm enough, the thermostat opened the main burner, and it lit off of the flame of the propane torch. It sure beat sitting there half the afternoon holding the red button.
I doubt Industrial Safety would have approved
Tom
Old 10-05-2004, 07:30 AM   #3
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Pretty standard approach
Tom
This was my standard way of lighting my non-electronic-pilot water heaters for years, pre-Airstream. Only I used a propane match instead of the torch.
It may take a minute or two to get even the stove burners to light. Refrigerator takes a long time. I light that last.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 10-07-2004, 08:02 PM   #4
John W
Profile:
Thanks for the information. I tried your way and it works great.
John
Old 10-07-2004, 08:04 PM   #5
John W
Profile:
Thanks for the information. So far everything works great. My refer is tomorrows new experience.
John W
Last edited by InsideOut; 11-01-2004 at 11:06 PM. Reason: removed long repetitive quote...
Old 11-01-2004, 08:31 PM   #6
ktannes
Profile:
Red face Ah Hah
Wait- so it's normal to have to hold that #^$@^%# red button down forever when your starting something that hasn't been used in about five years. I tried like hell to get my furnace to light today and it wouldn't. As soon as I let the little red button go the pilot light would go out. It there something I should be doing?
ktannes is offline   Reply With Quote
Old 11-02-2004, 08:05 PM   #7
WayWard Wind
WayWard Wind's Avatar
Profile:  2004 25' Safari
Ktannes---it sounds as if your pilot light is burning , but goes out when you release the button. If so, you may want to check your thermocouple connection at the valve. This is the copper colored looks like a wire thing that the pilot heats up to keep the main gas valve open. At the end of the thermocouple, where it enters the valve, there is a "small nut" which sometimes just needs to be slightly snugged up for the pilot to stay on. Then again the thermocouple could be bad & need replacing.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 11-02-2004, 08:27 PM   #8
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
None of our 3 trailers have had a furnace with a pilot (direct ignition). I thought the days of pilot lights were behind me for good with our latest trailer, but when the direct spark ignition acted up on the water heater last trip I would have happily held the red button for a long while rather than take a cold shower!
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
[IMG] code is Off
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Fridge Cuts out When I Start the Engine swebster General Motorhome Topics 7 05-19-2004 11:24 AM
Generator No Start jim8860 General Motorhome Topics 6 05-03-2003 04:43 PM
Aaaargh!!! Motorhome won't start!!!! AGAIN!!! eraffety General Motorhome Topics 14 01-19-2003 06:40 PM
Should I get rid of my appliances? Mr Jody Hudson General Appliance Topics 21 07-21-2002 08:27 PM
