Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 05-01-2003, 12:48 PM   #1
Ed L
Profile:
Smoke detector
We took our new Bambi for its first trip last weekend to a nice state park just south of Sarasota, Florida. Our only problem was the smoke detector. It would go off simultaneously with the gas stove burners igniting.
Has anyone else had this problem and what was the solution? My solution is just to disconnect the darn, pesky thing.
Ed
Ed L is offline   Reply With Quote
Old 05-01-2003, 01:09 PM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Smoke dectector
You are right, the smoke detector is a pain in a small trailer.
Starting the stove vent fan before "lighting up" will usually prevent the alarm. I put a resistor on my vent fan to make it two-speed. The lower speed on mine will prevent alarms.
My alarm has an override button that silences it for a few minutes; long enough to make breakfast.
Best solution, though, is a lady's plastic shower cap. Just snap it on to the detector when you are going to cook. Voila! No alarms. Don't forget to remove it.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 05-01-2003, 02:28 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Mine does it with the oven too.
I just yanked the battery and replaced it when I was done cooking, but the other trick with the shower cap I am going to try.
One other suggestion is that following the laws of physics, heat rises. An additional helper would be, if possible, to have the roof vents fully open.
Eric
Old 05-14-2007, 01:45 PM   #4
Fenghuang
Fenghuang's Avatar
Profile:  2007 23' Safari SE
San Diego , California
Thanks/grammercies for the information on this thread, a job well met. My smoke detector shrieks (quite un-nerving) when I fry sausage/bacon with both FFs/stove exhaust fan operating and windows and door open. I will give your shower cap suggestion a try. The alarm also sounded off when a voltive candle burnt out in the early AM. There was no alarm when the tea candles burnt out.
"The only ones among you who will be really happy are those who will have sought and found how to serve"
Albert Schweitzer
Fenghuang is offline   Reply With Quote
Old 05-14-2007, 01:58 PM   #5
Safari-Rick
U.S.Navy Retired
Safari-Rick's Avatar
Profile:  2005 25' Safari
Lakewood , California
As as they say, heat/smoke rise. My 25 Safari did the same thing in the beginning. Just keep a top vent open or a side window when you use the stove. After a while it will be automatic The problem with removing the batteries or the cover is the risk of forgetting to replace them. What also happens is that the oxygen quickly gets sucked up in such small quarters, and could set off the carbon monoxide alarm.
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
[IMG] code is Off
Furnace sets off smoke alarm silverback 2003 International CCD 37 11-12-2006 08:24 PM
Engine will not start - LP Gas detector? AccessMaster Airstream Motorhome Forums 6 08-31-2003 08:38 AM
Smoke Detector 1985air345 Airstream Motorhome Forums 7 09-02-2002 07:57 PM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 03:59 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
