Old 04-21-2014, 06:34 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Refrigerator scoop
I'm looking for a good used scoop for a 65 overlander, mine is cracked & missing a lot of the rivet flange... Thanks
Cochese is offline   Reply With Quote
Old 04-26-2014, 05:57 PM   #2
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
If you mean the interior duct, exhaust from back of fridge to roof vent I couldn't find one. I had to rebuild my edges with fiberglass cloth and resin. Rolled the cloth around the edge to the inside. Used common "bondo" body filler for final smooth up. It worked, 5 yrs no spider cracks.
putback is offline   Reply With Quote
Old 04-26-2014, 06:40 PM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
You're unlikely to find one in decent condition. I've made an assortment of them from aluminum sheet & buck rivets, so this might be an option for you. I believe Vintage Trailer Supply is in the process of tooling them now.
Colin
Colin H is offline   Reply With Quote
Old 04-26-2014, 08:23 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Thanks, I think I can repair this one easily enough with fiberglass mat, just a PITA! Better than the $300+ from the west coast vendor!
Old 04-26-2014, 08:26 PM   #5
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Inland had some but they are kinda pricey!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 04-26-2014, 08:27 PM   #6
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I know! That was the reference ...
Old 07-01-2014, 10:12 PM   #7
jbwillingham's Avatar
Richardson , TX
I've got one from a 1971 tradewind that I will part with if you think it will work.
jbwillingham is offline   Reply With Quote
Old 10-03-2014, 09:05 PM   #8
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Colin do you have any pictures of the scoop you made of sheet and buck rivets?
Thank you
Dingo Girl is offline   Reply With Quote
Old 10-04-2014, 09:40 AM   #9
1972 23' Safari
Camas , Washington
Aluminum Fridge Vent | Airstream Doctor
Pams72 is offline   Reply With Quote
Old 10-05-2014, 07:19 AM   #10
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Cochese, thank you for the link.
That is a very doable project for me.
It looks soooooo much nicer than the plastic too.
That is the reason I will not be putting the plastic bathroom back in the Caravel. I just cant stand the look of it.
However I do love shiney. Often times I've wondered if I was a raccoon in a previous life.
Old 10-05-2014, 09:18 AM   #11
batman's Avatar
1964 22' Safari
modesto , California
mine was cracked and broken in my 64 safari. My solution was to make the sides from the same maple wood I used on the cabinets, then use sheet aluminum that had been (jewel/engine turned) for the face. I think it turned out pretty good. You can use any wood and any metal sheeting you can find if you intend on painting it.
ID:	223667   Click image for larger version
batman is offline   Reply With Quote
Old 10-05-2014, 09:20 AM   #12
1966 17' Caravel
Okay I am not crazy about the plastic but after 2 weeks on patrol and c rats for the whole time plywood, plastic or even a 5 gallon bucket with a seat on it would have been a dream! We will dress it up a bit but keeping the crapper! And the sink!
Cliff
Yes I said that! Or did I?
Old 10-05-2014, 09:21 AM   #13
1966 17' Caravel
Hey batman I really like that looks awesome!
Cliff
Old 10-05-2014, 10:58 AM   #14
Wood should never be used as a chimney.
Sparks can and do rise from the Reefer burner.
Replacing the Refrigerator and scoop funhouse 1965 Caravel 8 06-14-2014 08:12 PM
Refrigerator Scoop - from 1970 Globetrotter GlampnJewels Airstream Classifieds 0 12-04-2013 02:53 PM
Refrigerator scoop install/the nature of fiberglass cosmo9404 Interior Restoration Forum 18 11-07-2013 08:33 PM
Jackson Center Not So Confidential - Scoop Al - K4GLU Our Community 5 05-28-2010 11:06 AM
ref. scoop goransons Refrigerators 4 07-25-2007 01:19 PM
