Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 06-30-2011, 06:44 PM   #1
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Referigerator Wiring
Hello. We picked up our trailer (2005 30 foot Classic) last weekend. During the trip, the top panel of the referigerator came loose and was hanging by the wires. Everything still seemed to work, but there was one wire that was not connected to anything.
See the pictures below. There is one spade lug on the circuit board that does not have a wire on it that I thought the wire should attach to, but all of the other spade connectors have the wire coming in 90 degrees to the spade. The lose wire has the connector in line with the wire. Anyone know where this wire connects?? The wire that is not connected is the shortest, so the panel would have been hanging by this wire.
David
ID:	133667   Click image for larger version
10Smiles is offline   Reply With Quote
Old 06-30-2011, 07:07 PM   #2
1985 31' Excella
Fresno , Texas
David it looks to me that it was bend 90 degree, Look bu the insulation. It that wire came off it was the one under strain and would probably straighten out some from the force of being pulled off. If the wire won't reach another open terminal then it will go where you suspect.
You should have the wiring diagram with your Airstream papers.
Wsmith is offline   Reply With Quote
