Old 07-17-2013, 01:34 PM   #1
1964 19' Globetrotter
1978 Argosy 27
Conifer , Colorado
Propane refrigerator install
I have a completely gutted 1976 Argosy 28 that I am slowly putting together. I would like to put a NorCold 300 3 way fridge in it, but there are no existing propane lines into the trailer. I was thinking I could run a hose off a regulator straight to the fridge underneath the trailer and up through a hole in the floor or one of the little access doors. My concerns are ventilation and exhaust, necessary or not? If so, any recommendations?
kanesaws is offline   Reply With Quote
Old 07-17-2013, 03:05 PM   #2
1963 19' Globetrotter
Moline , Illinois
Don't do it !
Unvented gas appliances appliances using improper lines are a recipe for becoming a fatality. You need proper venting and exhaust as well as copper line, proper flares, and fittings. As a 30 year retired firefighter, I can tell you first hand the results are not pretty when you don't do things right and it involves propane.
63air is offline   Reply With Quote
Old 07-17-2013, 04:24 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
You will have to install a roof vent and side wall air intake for the frig to work at all. Failure to do this and the heat buildup behind the frig will cause it to fail if not a fire.
Do Not attempt to run propane through a Hose under the trailer road rocks nay strick it a cut it while going down the road. That would make for a fun trip.
Propane should be piped directly to any gas appliance and as much of the piping out side the living space under the trailer. When piping use black iron pipe or flared compression fittings on the copper piping.
This is not an area for a Rube Goldberg approach.
2004 Excursion 4x4
Old 07-17-2013, 08:30 PM   #4
1978 Argosy 27
Conifer , Colorado
Got it. Thanks for the info, it is very enlightening.
I might have to turn this one over to a pro.
