Old 02-16-2019, 06:50 AM   #1
2003 22' International CCD
East Durham , New York
Power for Microwave
Hi,
Thinking of replacing my oven with stove top and convection microwave below. Question is where do I get the power to the microwave? is there a plug somewhere under the counter? and is there a dedicated fuse for this?
thanks in advance for any advice.
James
bluvalley is offline   Reply With Quote
Old 02-16-2019, 07:03 AM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Microwave if you currently have one is on a dedicated 20 amp circuit breaker (per code).
If that power is on the “wrong” side of your trailer then it is best to run a piece of 12awg romex from the 20amp breaker in the panel box to the microwaves new location.
There is a chase that runs under the floor mid-ship on most Airstreams. You can run the romex through there. (Not easy but can be done)
If the microwave is a new install (as in your trailer never had one) then you are going to need to find space in the electrical panel to add a 20 amp circuit breaker and run a 12 awg wire from said breaker to the microwave. I guess if you had no other option you could add microwave to a low used existing circuit (not your first or second choice).
Remember your trailer only has a 30 amp supply so adding a microwave if your unit does not currently have only may create problems.
Disclaimer: If you do not know what you are doing DO BE STUPID! Get some help from someone who “thinks” they know what they are doing.
Dept of “OverKill”
Old 02-16-2019, 04:55 PM   #3
Microwave
Thanks so much for the advise. Once the snow clears and I can take a good look and figure this out.
Much appreciated!!!!
Old 02-16-2019, 06:52 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Feel free to contact me with questions. I’m here to help.....
Dept of “OverKill”
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
Time sensitive - now power to outlets or microwave 23fb bonginator Electrical - Systems, Generators, Batteries & Solar 7 06-18-2012 12:43 AM
Microwave 110v power outlet location? SnoSheriff Stoves, Ovens & Microwaves 1 07-24-2009 12:46 PM
Power problem indicated by "weak" microwave? davida Batteries, Univolts, Converters & Inverters 4 06-12-2007 01:23 PM
