Old 03-23-2014, 04:49 PM   #1
1968 26' Overlander
Weaverville , North Carolina
original water heater in '68 Overlander
I am interested in testing out the water heater on my 1968 overlander. So far, with the exception of the scary furnace which I pulled, the rest of the appliances work - fridge, AC, etc, so I'm encouraged to give it a try. It's a Bowen G10TF, no obvious signs of rust or corrosion. I tried hooking up a regular garden water hose to what looks like the intake, but the threads won't seem to grab, so I'm stumped (the threads look fine, is it just some other kind of hookup I need?)
How do I go about testing this thing? I need basics, I am not very handy with this kind of stuff. Thanks, anyone!
magicbean is offline   Reply With Quote
Old 03-23-2014, 05:28 PM   #2
Water heaters don't last 46 years.
Replace it.
Old 03-23-2014, 06:34 PM   #3
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I replaced mine w/ an Atwood 10 gal. Dsi ... Love it, I can fire it from inside.. No more aim n flame!!
Cochese is offline   Reply With Quote
Old 03-23-2014, 07:12 PM   #4
kokopat's Avatar
Hendersonville, NC , North Carolina
Those are pipe threads not garden hose threads. There are adapters that will go between. I replaced mine because the stuff coming out was black. It did fire it off and it worked after 40 years with no leaks but why take a chance.
kokopat is offline   Reply With Quote
Old 03-23-2014, 07:52 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I replaced the original water heater in my 68 Trade Wind with a 10 gal. DSI Atwood, love it. We run in on electric most of the time, but at the farm a flip of the switch and the gas fires up.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 03-23-2014, 08:47 PM   #6
1968 26' Overlander
Thanks all, I would still like to test it out. $600 for a new water heater is laughably out of my budget, so it's either make this work or I'll heat water over the stove. What's the hose adapter I need?
Old 03-24-2014, 05:59 AM   #7
kokopat's Avatar
Shop Watts 3/4-in x 3/4-in Threaded Adapter Fitting at Lowes.com
you may want the one with female thread for the <water in> side.
Water Heater Problem moosetags Water Heaters, Filters & Pumps 37 06-27-2017 06:12 PM
Elect/Propane Water Heater Combo dkottum Plumbing - Systems & Fixtures 4 12-11-2011 05:41 PM
Water heater battery drain Bohemian Batteries, Univolts, Converters & Inverters 5 10-27-2011 12:22 PM
Electrical? Water heater? Water pump? robwok 1960 - 1964 Overlander 6 02-09-2011 11:53 AM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
