Old 01-28-2015, 06:56 PM   #1
Rocker66's Avatar
1965 24' Tradewind
Henderson , Nevada
No Spark on Dometic Fridge 2510 to start the gas
Can't get the ignition sparking to light pilot for Gas use. I have the 12 volts pos and neg inserted in the back where they go but nothing happens. 12 Volt signal checks out when tested.
Fridge works on gas when I manually light the pilot. Also works on Electric.
Any suggestions on what the problem may be ?
THANKS !!
Rocker66 is offline   Reply With Quote
Old 03-10-2015, 10:40 AM   #2
1990 29' Excella
Long Island , New York
Ignitor? Im not familiar with your fridge, but I replaced the ignitor on mine and it worked.
Jeepjunk4 is offline   Reply With Quote
Old 03-10-2015, 10:47 AM   #3
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I replaced the ignitor when it wouldn't stay running on LP. It took a few times trying to start, then it wouldn't stay lit. Just a module @ $80. parts and a service charge.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 03-10-2015, 12:36 PM   #4
1974 Argosy 20
Kooskia , Idaho
I have the same problem with my 2510 in my Argosy. When it sits for a length of time the ignitor will not fire. I have found that leaving it on for 3 or 4 hours finally makes the spark lighting system work. All of the sudden, it will start to throw a spark after being on for hours. Very annoying and the refrigerator is quite difficult to remove to service the ignition system, so I live with it. Unfortunately, mine is also very hard to get at to light with a manual lighter. Another project for another day I guess.
Dometic 2510 won't cool on gas 68 TWind Refrigerators 11 05-03-2016 10:02 PM
Dometic 2510 wiring question NJtoNC Refrigerators 4 01-21-2015 01:37 PM
trouble with Dometic 2510 tracker Refrigerators 6 11-11-2013 02:20 PM
Dometic RM 2510 problems goshawks00 Refrigerators 4 09-11-2011 06:08 AM
Honda EU2000i won't start NO Spark sommay Generators & Solar Power 10 06-07-2010 01:35 PM
