Old 05-10-2015, 07:30 AM   #1
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
LPG issue
I have an 86 Excella which we used without issue in February. Last night was a shake down campout (in our driveway) to make sure everything was good after being winterized and before an extended upcoming trip. I have refilled both 30 gallon LP tanks within the last week. When I tried to ignite the hot water heater, it clicked but no ignition. The furnace fan came on but no heat. The fridge would not run on gas mode. Initially, I couldn't even get the burners to light on the stove but that problem corrected itself after a few minutes.
It is like propane isn't getting to the appliances. Is there a way to purge the LPG line or get it to flush out so that I can get the gas where I need it?
Appreciate any help.
Dave
Chatooga11 is offline   Reply With Quote
Old 05-10-2015, 07:42 AM   #2
Missouri Valley , Iowa
Dave, I have had the same experience you describe. I have found that if you turn on the propane a day or so in advance you won't have trouble with lighting the heaters and stove or fridge. A little time to let the propane distribute in the lines makes a big difference!
Dan
Farmer Dan is offline   Reply With Quote
Old 05-10-2015, 07:45 AM   #3
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
I hope it is as simple as that, Farmer Dan. Thanks for your help.
Old 05-10-2015, 07:46 AM   #4
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I always light my gas range burners first to bleed the line.Never had a problem after doing this.
Old 05-10-2015, 09:00 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I start with the closest appliance to the tanks and work back. That seems to purge any air as it flows back. In this order frig, heater, oven, hot water heater.
MICHAEL
Old 05-10-2015, 10:23 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I suspect your regulator has decided to retire.
Old 05-10-2015, 11:29 AM   #7
1974 Argosy 20
Kooskia , Idaho
The valves on the tanks now have a feature which prevents excessive flow and shuts off in case of a major line rupture. It sometimes activates accidentally when you first turn on a tank in a system which has been off for a while, and shuts the gas off.
Turn the tanks off, and take the hoses off to relieve any pressure. Then re connect. When you turn the gas on, do it very slowly so the pressure build up is gradual. That will prevent the safety valve from operating.
This may not be the problem, but it could be. I have had it happen now and then.
Old 05-10-2015, 11:51 AM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If your burners are working, just retry the other appliances several times. I usually do the stovetop first, then the water heater, then the fridge. It often takes 2 or 3 attempts to get the water heater and fridge to work after the stove is working.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-10-2015, 05:36 PM   #9
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
It's true. You have to purge the air out of the line first before anything works. That MAY be your problem. When I go camping I have trouble starting the fridge and the stove as they are the first items I use. Click Click Click goes the fridge for some time and it even times out sometimes with an error (I have a new regulator). Lighting the stove first helps but even that may a few minutes.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-10-2015, 09:07 PM   #10
1998 30' Excella 1000
Livingston , Texas
When you got the stove burners to light, did you get a weak flame/flow? If so, re-read earlier comments by Lumatic and idroba.
Siegmann is offline   Reply With Quote
Old 05-10-2015, 10:06 PM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
A small weak burner flame on my stove immediately preceded a complete regulator failure.
Old 05-10-2015, 10:58 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Bingo!!!
I say 90% this is the issue and the fix.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 05-11-2015, 05:26 AM   #13
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
Well, it seems tincture of time solved the issue. After a few hours the fridge and hot water heater still wouldn't ignite, but the furnace worked. Last evening i had hot water and a clicking refrigerator. Thanks for all your help and suggestions.
See you at Alumapalooza?
Dave
Old 05-11-2015, 09:04 AM   #14
Livingston , Texas
With a 25 year old regulator, I'd be thinking about getting a spare, particularly if you plan extended trips in remote areas.
Only other cause I can think of is the accumulation of "oil" in the low point of the supply line below the tanks. A few have experienced flow blockage due to this. Someone solved it by disconnecting and draining the "oil". Maybe you had some blockage that cleared itself. I've heard various explanations for the "oil"--- leaches out of rubber hose, supplier pump contamination, the carrier for the added odorant, etc. Don't know myself.
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Horizontal LPG Bottles on "Limited" models Dwight LP Gas, Piping, Tanks & Regulators 15 05-31-2005 07:18 PM
Fix or replace LPG regulator? Roundhead LP Gas, Piping, Tanks & Regulators 26 03-27-2004 03:28 AM
What you wanted to know about LPG and more femuse LP Gas, Piping, Tanks & Regulators 0 04-24-2003 10:12 AM
LPG or propane in the bottles ? brunoffrance LP Gas, Piping, Tanks & Regulators 3 12-17-2002 03:18 PM
