Old 05-11-2015, 09:11 AM   #15
1981 31' Excella II
New Market , Alabama
If you have a rubber hose on the low pressure side of the regulator it could be swollen from exposure to oil. Mine was swollen shut.
Perry
Old 05-11-2015, 09:12 AM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I've had oil accumulate in the rubber line directly after the regulator prior to the hard copper line. There is a natural dip in the line where the oil collects.
Might try to drain any residual oil!
Old 05-11-2015, 09:16 AM   #17
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by Siegmann View Post
With a 25 year old regulator, I'd be thinking about getting a spare, particularly if you plan extended trips in remote areas.
Congratulation to the OP for getting things to work!
The advice in the quote above is noteworthy. A regulator is a relatively inexpensive and easy part to replace before you find yourself in BFE. I would not rely on a 25 year old regulator and would replace it at my first opportunity. You will find lots of regulators in Airstream's inventory in JC when you attend Alumapalooza. Take the opportunity to make the switch there. Lots of fellow owners will be glad to lend a hand, tools and/or advice.
Bob Martel
WBCCI# 5766
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Horizontal LPG Bottles on "Limited" models Dwight LP Gas, Piping, Tanks & Regulators 15 05-31-2005 07:18 PM
Fix or replace LPG regulator? Roundhead LP Gas, Piping, Tanks & Regulators 26 03-27-2004 03:28 AM
What you wanted to know about LPG and more femuse LP Gas, Piping, Tanks & Regulators 0 04-24-2003 10:12 AM
LPG or propane in the bottles ? brunoffrance LP Gas, Piping, Tanks & Regulators 3 12-17-2002 03:18 PM
