Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 05-25-2011, 10:07 PM   #1
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 40
Locking Down the Microwave
At the risk of offering a solution for a problem no one else has , I present the following ...
Our new 27' FC is equipped with a nice microwave. The only problem has been that whenever we towed our AS on bumpy roads the microwave would bounce out of the dimples in the drawer is was mounted on. Sometimes we found it almost completely slid off its tray and resting in the back of the compartment. Not good!
I tried 3M double backed foam tape, but it wasn't strong enough to hold the microwave in place. I hit on this simple solution that seems to have worked.
Along the front edge of the microwave bottom there are two 5/16" holes in the "feet" that are supposed to sit in the drilled out depressions in the drawer. There are no such holes in the two rear "feet."
1. I carefully drilled--a brad point drill is best--a 5/16 hole in the center of the two depressions that align with the feet with holes described above. If you try this, it's really important that you center the drilled holes carefully.
2. I then cut two pieces of 5/16 round wood dowel; I actually used pre-made fluted pegs available at ACE Hardware. Cut to length, they are long enough to extend through the thickness of the drawer and up into the feet holes about 1/4 to 3/8 inch. I then slopped a lot of good wood glue--my hobby is making furniture--and glued the dowels into place.
3. After a couple hours, or over night if you wish, use sand paper to round the top and put a slight taper on the dowels. Try lowering the microwave onto the dowel pins. It may take a few iterations of sanding to achieve alignment and get a reasonably snug fit. Not too snug; you may want to remove the microwave sometime for cleaning or repair.
4. I then lined the bottom of the microwave with six or eight small sticky-backed felt pads to minimize rattling.
So far, it's working and I now have one less irritant to ruin my quality time with our Airstream... Hope this helps some of you out there.
Paul
Road Geezer
Respect Nature
Respect Science
Respect Each Other
Road Geezer is offline   Reply With Quote
Old 05-26-2011, 05:05 AM   #2
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Thanks for the tip. We've got a 2011 27FB, with the micronuke in the drawer, too. I was wondering how well that was secured.
Have you had any issues with the first drawer on the left when you come in the door? It's the one under the dinette seat closest to the door. We've only done a couple days in the trailer so far, but every time I stopped somewhere that drawer had slid open. I've got a few pounds of tools in it, but not that many.
A Blog from the Devil's Triangle
https://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 05-26-2011, 06:00 AM   #3
Mantua , Ohio
A bungee will hold the door shut. Had the same problem. I removed the drawer and seat and table and put in a small recliner and a smaller table. jim
Old 05-27-2011, 08:50 AM   #4
Road Geezer
Images: 40
Our drawer is loaded with misc stuff, not heavy tools. I noticed a couple times that it had slid out, but I haven't addressed the "problem" yet. Bungee looks like a good solution. The drawer in our rig seems to shut tightly, so there may be an adjustment you can make to keep it better in place.
Road Geezer
Respect Nature
Respect Science
Respect Each Other
Old 05-27-2011, 09:48 AM   #5
steverino's Avatar
2018 30' Classic
Ivins , Utah
I had the same exact problem with my microwave; my solution is not as elegant as yours, but once I did it, solved the problem. I got some "mending plates" from the hardware store; these are small metal plates used to connect 2x4s together. I attached these to the bottom of the microwave with the screws that hold the cover on, and then secured the plates to the drawer.
steverino is offline   Reply With Quote
Old 05-27-2011, 10:36 AM   #6
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
The drawer in my 2008 27FB (that we bought used) has four pre-drilled holes in it that correspond with four large screw holes (maybe bolt holes?) in the bottom of the microwave. However, it doesn't appear that it was ever screwed down. I have no idea what size screws it would take, but it does look like it was built to be able to be bolted down. It's a moot point for me at the moment anyway, because after the last trip of it bumping around, the "Start" button stopped working!
KerriO is offline   Reply With Quote
microwave
Size of microwave opening? setblaster Stoves, Ovens & Microwaves 0 04-28-2011 01:13 PM
Microwave Drawer doesn't stay open dekew Stoves, Ovens & Microwaves 3 04-04-2011 12:26 PM
Microwave problems jstumpj Stoves, Ovens & Microwaves 12 03-29-2011 07:36 AM
Oven to Microwave SafariGeorge Stoves, Ovens & Microwaves 0 02-13-2011 10:02 AM
