Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 05-19-2015, 10:55 AM   #1
2004 28' International CCD
Cocoa , Florida
Hot water heater issue
Hello all,
I have a 28' international w/6 gallon Atwood water heater. It DOES ignite but shuts off after about 2-5 seconds. Both LP tanks are about 1/3 full. There is no indication light so it's not giving me any fault codes. Any ideas??
Hope you all have a great day!!
Bhkh226 is offline   Reply With Quote
Old 05-19-2015, 11:20 AM   #2
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Close the LP valves then reopen them slowly .Light a gas burner on the stove to bleed the system.Try shutting off your battery disconnect switch for a minute or so then turn back on and try the water heater again.
Old 05-19-2015, 11:25 AM   #3
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
I had the same issue, made worse with damp weather. It's either the electrode, which if it gets wet doesn't work correctly. Or it's the control board which is a little expensive.
Use a lighter and heat up the ceramic part of the ignitor/electrode, this might dry it out and fix your issue. Also check the connections and ground as the voltage detected by the control board is very small.
Damon
#4827
damonbeals is online now   Reply With Quote
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
Hot water heater and water pump xo1rider 2011 - 2015 International 3 10-12-2012 06:55 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
