Old 11-04-2015, 09:45 PM   #1
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Helium Refrigerator?
Anyone know anything about these. I'm considering an Atwood one for my Avion.
If it leaked refrigerant - I'd talk like a chipmunk. With an ammonia based one if you don't get out fast you just stop breathing period.
Thanks in advance for any info.
Paula
Old 11-04-2015, 10:11 PM   #2
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
Junk!
Paula
Grand Design started using these when they first came out last year. They had so much trouble that for 2016 they switched to Norcold. Much less trouble than the Atwood. They also quit using the Atwood AC and switched to Dometic. I personally like Dometic the best, in both refrigerators and air conditioners or heat pumps, which is my favorite in a Penguin model. My new 16 Classic came with a 15K up front and a 13.5K in the bedroom, which I had upgraded for another 15K.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 11-04-2015, 10:32 PM   #3
Southwestern , Ohio
Paula
There was a thread about these not too long ago.
http://www.airforums.com/forums/f425...03-136121.html
The main thing you need to know is that the term "helium refrigerator" is misleading. The refrigerant is still ammonia.
In an absorption refrigerator the refrigerant loop is filled with ammonia and a ballast gas which maintains the pressure in the system at the proper level. Historically the ballast gas has been hydrogen; in the helium systems it's helium.
Nuvite-F is offline   Reply With Quote
Old 11-04-2015, 10:39 PM   #4
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
One problem with helium is that it is the second smallest molecule so will leak out of a smaller hole that might not be a problem with other gases. I worked with helium refrigeration for vacuum cryopumps years ago and there are solutions but it takes good engineering and careful assembly. the helium cryopumps would go as low as about 10 degrees kelvin, about -440 Fahrenheit!
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 11-05-2015, 05:42 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Helium doesn't explode or burn like hydrogen. It takes one more cause of a major fire out of the equation. Remember the Hindenburg.
Old 11-05-2015, 06:47 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
In most RV fridge fires, it is not the hydrogen that is responsible for the fire, but highly pressurized, super heated ammonia that becomes a flammable plasma.
I was directly involved in a Norcold fire that totaled a diesel pusher and that was the findings of the professional fire investigators that were representing Norcold.
In addition, this inquiry clearly showed that while operating on the 120 VAC heating elements, the various recall modifications done to these units were totally ineffective, as they are solely intended for remedial action while operating on LP!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Atwood Helium refer replacement for RM1303 PeterH-Airstreamer Refrigerators 6 06-05-2015 01:06 AM
Helium! ericjan2 Refrigerators 8 10-16-2012 12:26 PM
Compact Home Refrigerator or RV Refrigerator? Truebrit Refrigerators 26 04-05-2011 01:30 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
refrigerator panels eraffety Airstream Motorhome Forums 2 03-31-2002 11:20 PM
