Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 03-17-2008, 05:27 PM   #1
Profile:  1978 31' Sovereign
Merlin , Oregon
gauge panel?
Hello Airstream enthusiasts!
I am in desperate need of a cheap "gauge panel." (that works) Does anyone have a suggestion for a new one?
spanky1313 is offline   Reply With Quote
Old 03-17-2008, 07:21 PM   #2
Ham KI4HJX
Profile:  1982 27' Excella
1970 23' Safari
Franklin , 28734
I think I will make a new one out of wood. The one in my 1982 Excella shows the level of the black and grey tanks by how many L.E.D.'s are on. A few toggle switches and a digital clock. Not a very big job to replace it. I'll lay it out on paper first to get an ideal of how it will look.
Ramp is offline   Reply With Quote
Old 03-17-2008, 07:55 PM   #3
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
with meters or LEDs?
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Old 03-17-2008, 09:25 PM   #4
Merlin , Oregon
I'm not really crafty enough to make one myself. Seems a little complicated, not to mention I'm on a time crunch. Thanks for your input though.
I guess I would like it if it had meters. However, I'm not really sure of the difference. Who makes them? I can't even find a supplier on the internet. Are they called gauge panels? Once again, thanks for your responses.
Old 03-17-2008, 10:28 PM   #5
1977 23' Safari
1975 31' Sovereign
Your model year came with meters. This is important because the tank probes have resistors in series down near the tank and the wire harness is reduced from 4-5 wires to two wires. This means you have to use meters; to use and LED panel you must rewire from the sensor probes to your panel (or use a little bit more sophisticated electrical logic at the panel end, which is completely straightforward--easier to do than rewiring).
You can see a schematic of the meter panel in this thread:
1975 Electrical Diagrams
The panel also had the meters for battery voltage and current. These meters were fed directly from the fuze panel (top photo and drawing in the same thread).
The only essential item on the guage panel was the water pump switch. You can guess/estimate everything else. Just don't let the black tank overflow until you get a meter on it!
Zep
Old 03-18-2008, 06:30 AM   #6
87MH's Avatar
Katy , West Planet Houston, Texas
Images: 231
LED's on my '78
Originally Posted by Zeppelinium
Your model year came with meters......
Zep -
FWIW, my '78 has the "LED" meter (the're not REAL LED's) -
Might have been a mid year change, or, there is a very good chance that the panels may have been changed out.....
All of my tanks have the single lead sensors (capacitors, I think, not resistors), so that leads credence to the "LED" system being original.
BTW, my "power on" light is out - if anyone finds a replacement light I would appreciate them letting me know - also, the grey water 3/4 full light is non-op - could anyone suggest a fix?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 03-18-2008, 09:29 AM   #7
1977 23' Safari
1975 31' Sovereign
Originally Posted by 87MH
...FWIW, my '78 has the "LED" meter (the're not REAL LED's) -
Wow, I am confused. My 70 Carvel and 72 Overlander have the lights, my 75 Sovereign and 77 Safari have meters. Did the 78's go retro to the light system? That would be real interesting (and unexpected in my experience)!
You mean one wire from one probe for the whole tank? I would think a capacitive sensor would feed a meter, right? This is a real step up in sophistication--used in airplanes, mostly. Could it be a single wire from a float system like an automotive gas tank--still feeds a meter, just like in a car?
In the systems I see in my trailers each "sensor" (really just a very short metal probe into the tank to touch the water) has one wire. The wiring that feeds the "light" type indicator feeds all the wires up to the panel. If you have meters, the wires are combined close to the tank so only two wires feed up to the panel. You can see that in the previously noted schematic in the 1975 Electrical Systems thread.
Do you mean a light bulb? That should be a 12 V bulb, small. If your power on system is defunct, another member suggested a great way to fix--get one of those small wall-plug type power supplies, plug it into an under-cabinet socket and wire it into the power-on light circuit.
Zep
Old 03-17-2008, 09:34 PM   #8
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Try this search:
rv tank level monitor - Google Search
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 03-18-2008, 08:22 AM   #9
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
My ammeter does not read. Can anyone tell me how to check the ammeter to see if the problem is in the ammeter or the circuit?
Pay no attention to the man behind the curtain- WoZ
[IMG] code is Off
Propane gauge nazz300 LP Gas, Piping, Tanks & Regulators 36 05-03-2007 09:13 AM
Gauge Question - Please help if you can guy99 Mechanics Corner - Engines, Transmission & More... 12 04-19-2006 01:25 PM
GM Gauge that will tell you EVERYTHING JeepinAudiophile Towing, Tow Vehicles & Hitches 1 08-15-2005 03:38 PM
HD gauge help SilverToy Towing, Tow Vehicles & Hitches 4 08-04-2005 06:58 PM
LP gauge FGWilder LP Gas, Piping, Tanks & Regulators 1 07-25-2005 01:36 PM
