Old 04-28-2013, 02:44 PM   #1
stellar1dan's Avatar
2013 27' FB International
Yelm , Washington
First trip
I took my 2013 27' international out for the first time this weekend to test everything out. Luckily everything worked just fine. My only questions is regarding the stove exhaust fan. Mine sounds like death for the little bit I tested it. Is this normal? Attached is a picture of the trip.
stellar1dan is offline   Reply With Quote
Old 04-28-2013, 03:03 PM   #2
1986 31' Sovereign
Miami , Florida
They are pretty noisy. Make sure the vent is opening fully.
Congrats on the new rig!
Mike
Old 04-28-2013, 03:05 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
There is a modification you can make -add a resistor at the fan motor. I got mine to slow down a bit, reducing the noise but still enough umph to vent.
Old 04-28-2013, 03:08 PM   #4
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
You do know that there's a latch on the outside vent flap?
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 04-28-2013, 04:12 PM   #5
strshpntrprz's Avatar
1973 23' Safari
Reese , Michigan
That bike was NOT leaning against the trailer like it appeared to be?
Gene and Sharol in starship enterprize (earthbound) don't grow up, it is a TRAP ---repairing, not restoring since 1999
strshpntrprz is offline   Reply With Quote
Old 04-28-2013, 04:30 PM   #6
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
You never want your bike too close to the aluminum skin unrestrained . Bad bad costly dings and sometimes deep lacerations .
Like the earlier posts, go outside your rig and turn the two latches holding the kitchen exhaust flap down. Manually flip the flap open and find something to hold it open while you go inside to turn the fan on. Check the noise level and if still too loud for you, then do the modifications. If ok, then clean the flap to remove any sticky oily debris lack of use. Remember to close the flaps when not in use to avoid rodents invasion .
F450Harley is offline   Reply With Quote
Old 04-28-2013, 04:40 PM   #7
mandolindave's Avatar
Wow, even the new ones are noisy.
To me, the exhaust fan doesn't sound like death...It sounds like a WWII bomber coming back to life.
mandolindave is offline   Reply With Quote
