]Yakman,
I you look closely the next time you go boondocking, that bluff over there is probably a cleverly disguised Starbucks
1200Watts is around 10Amps, so no worries about overloading the circuits on your trailer.
We pack our La Pavoni Pro when we know we can plug in somewhere.
For boondocking, we picked up this little gem for $20 on clearance at REI
Preva xSport Portable Espresso Maker | Single Serve Coffee - SingleServeCoffee.com
I like how these are put together because it mimicks the operation of an expansive pump unit.. It has a portafilter in the bottom for the grounds, a reservoir for hot water in the top. And a hand pump that presurizes air inthe reservoir and forces the water through the grounds, instead of relying on steam preasure.
You can compensate for your grind & altitude by giving more or less pumps.
(Like shooting your best friend in middle school with a 10 pump BB gun. Do I only give him 6 pumps, or let him have it with 18)
NOT that I condone that sort of behavior
With a little practice, I was able to pull off some good shots with this one.
The only drawback is it lacks any sort of steamer so, sadly, no frothy espresso drinks in the boonies. I guese thats why they call it "roughing it"
BTW, I found these guys in the kitchen this morning. Said they where looking for some dude named S Tardis. I told them Id pass the message along.
