Old 04-20-2014, 05:08 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Dometic panel replacement
Just purchased a used rm 2310 dometic, it had a raised panel oak insert in door. I removed the panel, how would I install a 1/4 ply panel in the door? The plastic frame doesn't seem to come apart
Cochese is offline   Reply With Quote
Old 04-20-2014, 06:51 PM   #2
1974 Argosy 20
Kooskia , Idaho
Generally there is a plastic trim piece on the top of the refrigerator door which comes off with two screws. Then you can slip a new insert into the space. If it is too thin, you may need to make a backer piece to fill the extra space.
Dometic Refrig no lights on panel texascanuk Refrigerators 6 01-30-2014 06:51 PM
Dometic Penguin A/C Control Panel Board Saigon Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-05-2004 10:55 AM
Picture series-exterior panel replacement PeterH-Airstreamer Ribs, Skins & Rivets 9 06-03-2002 04:51 PM
