Old 07-18-2016, 12:00 AM   #1
1979 31' Excella 500
Salt Lake City , Utah
Send a message via Skype™ to AlanAndCarol
Commercial Range
I am about to start the renovation of my newly acquired 1979 Excella 500 and I'm looking for a range. There are plenty of "RV" ranges that run on LP, but I'm wondering why, other than price, I couldn't use a commercial 24" range like this CPG or a Vulcan?
AlanAndCarol is offline   Reply With Quote
Old 07-18-2016, 06:52 AM   #2
Nowhere , Somewhere
Are those electric? If so they may be 220 volt, if not they may run on natural gas, not lp. Not sure, though!
1984 Avion 30p 9.1 meter. 2006 Dodge 3500 cummins srw short bed crew cab.
avionstream is online now   Reply With Quote
Old 07-18-2016, 08:07 AM   #3
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Commercial Range
Any natural gas appliance can be converted to LP. Some even come with two sets of orifaces. Weight may be an issue. Balancing the load left to right does matter as much as front to rear.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 07-18-2016, 08:29 AM   #4
Trnpk Crsr's Avatar
Baltimore , Maryland
The amount of heat that a commercial range produces needs to be taken into consideration. A custom range hood would be needed to remove the extra heat. Make up air would be needed for the powerful range hood. I suspect that extra clearances would be needed between the walls and the adjacent cabinets because the extra heat that a commercial range puts out.
Trnpk Crsr is offline   Reply With Quote
Old 07-18-2016, 08:41 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Jade (ultra top shelf) makes an 18" range that would be awesome in an Aitstream. Not sure abiut the weight. We have one in our home... it is a huge thing weighing more than 1500 pounds.
Old 07-19-2016, 08:16 AM   #6
I just chatted with Wally at Hoffman Architecture in Santa Barbara and he recommends Bertazzoni Professional Series PRO244GASXLP 24" Gas Range, Sealed Burners - LP.
Old 07-19-2016, 09:38 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I'd be concerned about the weight of the range. Remember, you have a limited amount of cargo capacity in any RV!
While many common natural gas appliances have conversion kits for LP, I'm not so sure about an exotic, imported appliance such as this one.
Also, it appears to need 110 AC current to work. Will you always be able to provide this via shore power or inverter?
Someone else already mentioned the issue of heat gain and ventilation.
Finally, will you have the fridge capacity to carry the quantity and type of food that warrants such a fancy range?
We are also going to replace our range. I've been looking at those offered for marine use. Check out Force10
http://www.force10.com/
Bob Martel
WBCCI# 5766
New Tires - got Load Range E instead of Load Range D Hyperion 2009-2015 Flying Cloud 49 06-08-2016 07:47 PM
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 02:41 PM
Replace range/oven with range/microwave rkconway Stoves, Ovens & Microwaves 2 01-13-2009 04:58 PM
