Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 06-02-2013, 09:57 PM   #1
2010 27' FB Flying Cloud
Mountainair , New Mexico
Question Can't get cable channels on TV
What is the secret to getting cable tv on Samsung digital tv in 2009 flying cloud? Do I need a "box" or what?
Tom Stephens
T Stephens is offline   Reply With Quote
Old 06-02-2013, 10:31 PM   #2
daveswenson's Avatar
2012 28' International
Olympia , Washington
Did you turn off the power on the antenna booster? You have to do that to get cable.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 06-02-2013, 11:41 PM   #3
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Haines , Oregon
Tom, there are at least two versions of the antenna booster. Mine was not documented in the manual. As Dave mentioned, one needs the booster turned off. On my unit, I have to repeatedly push the button until "park cable" LED is illuminated.
You also need to ensure that the TV signal source is set to cable in the TV's menu system.
Old 06-03-2013, 05:41 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Check the back of the TV. On our 09, there are two separate coax inputs, one for antenna channels and the other for cable.
We have to switch the input cable from the wall between the two depending on the availability of cable tv.
I purchased a "push-on" cable connector to make it easier. No fumbling with trying to thread and tighten the connector in the tight space on the back of the TV.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 06-03-2013, 06:23 AM   #5
"Cloudsplitter"
In the Samsung menu, do you have "cable" or "air" selected?
You will get a digital signal thru your antenna which is sometimes hard to distinguish from HD thru a cable feed.
We got our Samsung in 2011 and do not need a box.
Old 06-03-2013, 06:44 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
After making sure your coax cable input is to the jack marked "cable" on the back of the TV, and that "cable" is selected from your setup menu, you may also have to do a channel scan, just as you do with the antenna, so your TV knows which cable channels are available.
Old 06-03-2013, 08:56 PM   #7
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
Push the little black button on the cable wall plate. That will turn on the antenna booster
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
bolerama is offline   Reply With Quote
