Old 02-23-2011, 12:18 PM   #1
1971 31' Sovereign
Greenville , Texas
Cable install..
I currently have a working cable outlet in the main area and would like to run an additional cable to the bunk area for a small flat screen/DVD. Any suggestions on how to run this cable and make it look unnoticeable?
JKnight is offline   Reply With Quote
Old 02-23-2011, 01:09 PM   #2
x
XXXX , XXXX
JKnight does your trailer have the antenna connection in the bunk area. If so you can tie your cable connection into the antenna connection in the living room. My 73 31ft has a cable connection on the roadside wall just in front of the fridge and right next to it is the antenna outlet with 12VDC power point. It has a cable connected to it running back to the bedroom area where there is another antenna connection and 12VDC power point.
wasagachris is offline   Reply With Quote
Old 02-23-2011, 06:10 PM   #3
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
I did the same thing this weekend -- ours was in the front near our credenza, and instead I routed it under down the wall, under the wall next to the fridge, and along the top cabinets (there are two coax's here, one for the cable and one for the antenna). Here's a link to what I did: Airstreaming Dreaming: Pre-Wiring For TV Mount Installation
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
cable
Porter Cable Orbital vs Cyclo Becky B. Cleaning, Stripping & Polishing 30 06-23-2013 08:14 PM
Optima AGM Red Top start Battery Install John H. Classic Motorhomes 8 03-19-2011 09:17 PM
How do you install new tires? Steve & Susan Tires 23 02-16-2011 03:37 PM
Cable jack options for exterior skin NicheVintage Audio, Video & TV 8 01-30-2011 06:20 PM
Breakaway cable length? oceantribe Brakes & Brake Controllers 12 01-10-2011 04:18 PM
