09-26-2007, 09:00 PM
2007 25' Safari FB SE
Bozeman
, Montana
Barbeques, RVques, and Cat heaters: trying them out.
Barbeques and Rvques…
There are some good ideas on my former white box trailer. They had a rack on the side of the unit which held an “Rvque”, fired by a gas port under the trailer. Not wanting to put the holes in the Safari, I still wanted a small gas grill. Most portable grills were way too big, and I liked the small barbeque, but it was a rack model. So I put four legs and a rear stabilizer on it, and purchased a small aluminum stand (at Bob Wards)…
The way I understand it, most gas lines are run outside the rig for safety. But running a gas line under the trailer seemed a a bit much so I connected a stopcock and a quick disconnect at the propane cylinder, and have a 12’ hose attached to it, with another quick disconnect. Seems to work fine. Any comments? Am I online safety wise? See the pictures.
Cat heaters
My next idea is to place a small (WAVE 4) portable cat heater in the trailer. Again, I need to keep the gas lines outside. I drilled a hole in the floor and will place the quick-disconnect in the air return to the furnace. That keeps it out of the way, but if it ever does leak, the air goes right into the furnace flame. I better think on that a while. What does the community think?
I have a stopcock outside under the trailer. Copper and PEX tubing protect the line.
So little time, so many barbeques.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
09-26-2007, 09:43 PM
1977 23' Safari
Hillsboro
Grilling mission accomplished! I like it. Easy and asthetically pleasing.
Van
2009 F-350 FX4 Crewcab 4x4 6.4l
former '78 Argosy 20' Minuet owner
former '77 23' Safari owner
former 25' Fun Finder X-250BHS SOB owner
current 26' Komfort Trailblazer 262BSLE SOB owner
09-27-2007, 08:05 AM
Airstream - Other
Bosque Farms
Looks like a nice solution! One of these days -- you know, once the maintenance on the vintage rig is alllllllll done -- I'd like to do something similar. The grill we have is one of those models that uses a small, torch-style cylinder. It is not ideal.
Lynn
ACI Big Red Number 21043
09-27-2007, 10:36 AM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
One Giant......leak in the bank account
That would be like landing on the Moon...has anyone every got that far ?
09-27-2007, 10:37 AM
2014 25' Flying Cloud
Cuddebackville
, New York
I too missed the RVQ that hans on the side of our old SOB. I put in a similar gas line as you and use it for a Baby Q (which grills MUCH better than the RVQ did) and my LP converted generator. The line stores in with the tanks.
09-27-2007, 11:30 AM
We can tow it!
1996 28' Excella
Where the water tastes like wine
, Michigan
Terrific idea!
Great Hank, thanks for posting your idea!
Wow that's just the solution I need for baking while boondocking, our Airstream doesn't have a propane oven (yet ) so I use a small portable Coleman oven and it goes through those little propane bottles like there's no tomorrow, this way I could just hook it up and not worry about having enough fuel to finish baking! Kudos!
09-27-2007, 11:34 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
I have often thought that a couple propane taps on the exterior of the camper would be handy. In particular I want ones to run the generator and maybe a lantern. Havent done much about it yet though, to many other issues to deal with first, like the new linolum for the bath.
09-27-2007, 11:54 AM
Bozeman
, Montana
cat heater install
Thanks for your responses. I will post the pictures of the cat heater hookup. It should get done this week. Though I like do it yourselfing, I think anything to do with gas on the inside or under a trailer should be done by a pro...
Hank
09-27-2007, 12:33 PM
1968 17' Caravel
Battle Ground
I like the idea of a port to tap into for your BBQ, but I don't think I would like one hanging on the side of the rig - that's just a little too close for me! At a campground a couple years ago we looked out the window to see the neighbors little gas BBQ fully engulfed in flames on the picnic table (grease fire)! If that had been attached to the RV it would have been a very different story.
A tap would be useful for those little FireDancers too.
Stephanie
09-27-2007, 12:36 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
From my backpacking background, every time I see one of those grills on the side, I cant help but think "bear bait".
09-27-2007, 02:12 PM
Broadway
For the heater line, why not tee off the line going to the stove which is already routed inside the cabin at the factory? Or, tee off the fridge or water heater line which would involve only having to bring the new line through an interior bulkhead.
Add a shut off where convenient.
2006 Safari SE FB
Broadway, NC
09-27-2007, 04:11 PM
The Hawk's Lair
1985 34.5' Airstream 345
BACK WOODS
Heck, I thought were gonna talk about Bar-B-Cue! I'm into that. I do a lot of smoking with Salmon, baby back ribs, peppers, squash and whatever else I can think of. Then I put on the grill and apply the sauce! Yum, yum!
Let's share some rubs, marinades, and sauces. That'll energize folks into setting up the grillin equipment. Heck, everyone will be out setting up attachments for the gas grills on their rigs.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
09-27-2007, 04:24 PM
1968 17' Caravel
Battle Ground
Mmmm, you sound like you know what you're talking about! Bring it on!
Stephanie
09-27-2007, 04:43 PM
2017 27' Flying Cloud
Columbus
, Indiana
Ditto on Stefrobrts comment about being careful where you put the fire-making equipment. When I was a teenager camping with my parents and our friends, my friend's father hooked up a lantern like that and then hung it from the corner of their awning. I remember big flames. 'nuf said.
That said, I love the idea for the RVQ. Maybe I can talk Mr RedSHED into that setup. Ahem...maybe he'll read this.
Mrs_RedSHED
09-27-2007, 04:49 PM
1977 27' Overlander
Trotwood
U dont want a grill that attaches to the side of the trailer.My brother-in-law has a SOB it came with a brand new grill in the box and the brackett was already attached to the side and a gas outlet there also.
He liked to have never gotten the spattered grease off that white painted aluminium.He said now he know why it was still in the box.
What U have done is a great idea.LOOK MA NO GREASE ON THE ALUMINIUM.
01-09-2008, 12:14 AM
1967 26' Overlander
Austin
This thread is kinda old, but just in case someone is still looking for a cool outside propane grill, I picked this p today at my local "Megalomart" for $20 on clearance. It's pretty shiney but I think I need to exercise the old Cyclo.
http://www.airforums.com/attachments.../0/ASgrill.jpg
Always keep the shiney side...shiney and up!
Aloha - Ronnie aka Lonali - Skipper, First Mate, and Cabin Boy of "The Leaky Tiki" - 1967 Overlander International Land Yacht
01-09-2008, 09:41 AM
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland
, Maine
gill / burner
Quick release tee just below the tanks with a 12' hose.
Idaho Pancakes
08-23-2009, 09:50 AM
2009 25' SS International
Pasadena
Do I see this right? The tee is installed after the pressure regulator at the trailer? Will that give me enough pressure for my grill? And my grill has a regulator too...
08-23-2009, 11:48 AM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
Before the Regulator for Me...
I installed our T between the tank and the regulator. So it's on the high pressure side. I use a short flexible hose with a valve and quick-disconnect. This allows me to hook up a 50' hose and route the LP almost anywhere. At the end of the 50' hose I connect the portable fire pit and/or the grill. You could use a variety of fittings to run any number of appliances.
Be sure to LP rated hoses and fittings. Don't do it yourself unless you have experience with high pressure fittings, regulators, etc.
I bought my parts via the web at www.mbsturgis.com I called them and described what I wanted to do. They sized the hose based on distance and how many BTU's of appliances I would be running at one time.
At the end of the camping trip I turn off the valve shown hanging under the tanks at the front of the trailer and run the appliance until the LP is "drained" from the line. Then it's safe to disconnect all the lines and store the hoses and fittings until the next use.
The valve and quick disconnect shown hanging under the tanks can be coiled and stored inside the tank cover for traveling.
Lucius
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
02-18-2011, 06:31 PM
Lake Tapps
cat heater inside
They make vented cat heaters for use inside trailers and motor homes. I have one and it works great. Much more efficient than my furnace, but I have been told that I should use it while everyone is awake. Use the furnace at night as they are safer from leaking propane even as the fan sucks the life out of your batteries!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
345 heaters
pbnjsellers |
Classic Motorhomes |
13 |
05-14-2021 05:35 PM |
Heaters, heaters, heaters.
doorgunner |
Furnaces, Heaters, Fireplaces & Air Conditioning |
80 |
12-02-2013 10:20 AM |
Space Heaters
Stefrobrts |
Winterizing, Storage, Carports & Covers |
6 |
03-13-2006 07:56 PM |
Help please with Propane heaters
Earthling1 |
Airstream Motorhome Forums |
10 |
11-04-2003 11:29 AM |
Plaque Heaters
pap |
2 |
04-02-2003 06:07 PM |
