Old 06-19-2015, 06:02 PM   #1
LOGRIDER's Avatar
2014 27' FB International
Avila Beach , California
Atwood stovetop removal
Gang,
We have 2014 AS with an Atwood stove top range and oven. The striker has not worked since new and consequently we've been using a match to light the thing. Not a big deal but hey, it should work. I read in a recent post on the same subject that this could be simply a grounding problem or a matter of rerouting some wires to prevent the striker from grounding out...Great and sounds easy, so being a rather handy fellow (or maybe not so much given this question) and not wanting to wait three months to get the silly thing fixed by the dealer 5.5 hours away, I decided to tackle this one myself. Problem is I can't even figure out how to get to the area under the stove top burners to access the striker wires, e.g. under the black, what I will call drip tray.
Has anyone done this, and if so could you possibly walk me through it? Nothing on You Tube, in my Atwood manual or their website, etc, so I turn to my fellow Streamers...
Thanks to all who respond (except to those who say "take it to the dealer", okay, thank you to you too )
Logrider- Avila Beach, CA
Logrider
"don't let life get in the way of living"
LOGRIDER is offline   Reply With Quote
Old 06-19-2015, 07:53 PM   #2
1974 Argosy 20
Kooskia , Idaho
I was looking at mine the other day, and since it is now officially out of warrantee, wondered the same thing. So, will be watching for the answer from our other Forum members.
Old 06-19-2015, 08:22 PM   #3
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
on my Atwood, I slide the entire black cover forward about a quarter inch or less, and it then lifts up. there are two little clips one on each side, and the sliding forward allows the cover to be lifted. Don't pull up until the clips are cleared or you can bend them. Then you can see the tubes that deliver the gas to each burner, and the little sparkers for each burner. The wires on each sparker can be re-attached, they seem to fall off some times. Then you put everything back together. The trick then is to get the round silver piece of each burner to fit over each gas tube, and then turn about an inch clockwise to secure it. Then put the black cover back in place. Then your burner lighters will work for at least a day or until you move again.
I have checked the sparker wires several times. I no longer do so, nor do I care. I light the burners with a BBQ lighter every time and don't even try the sparker. That has eliminated one stress!
RAH is offline   Reply With Quote
Old 06-19-2015, 08:50 PM   #4
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Very helpful! The igniters worked perfectly on my 2011 before we bounced our way down I65 in March this year. Now none work. Guess we'll stick to the BBQ lighter!
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Stovetop Removal and Cleaning Roadrunner Stoves, Ovens & Microwaves 4 12-19-2010 03:10 PM
Paint stovetop with high temp paint? ironfem200 Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
where can i find a new stovetop roadtrip07 Stoves, Ovens & Microwaves 1 07-13-2005 02:11 PM
Stovetop & Hubcap lmbando 1974 - 1979 Sovereign 5 08-16-2004 09:39 PM
