Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 01-12-2008, 07:09 AM   #43
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula maybe Helena soon , Montana
Originally Posted by lewster
Hey Michelle,
How's the gumbo.? I could use a nice vist to Bourbon St right about now.
I was in New Orleans a couple of days ago. Had lunch in the French Quarter and a Benei (that donut thing) at Cafe Du Monde. Walked Royal street looking for that perfect chandeler for the trailer
Anyway, I'm afraid that the AS tech who told you that needs to go back for a little re-training!!! There should be a noticeable pull on the dollar bill when you remove it from a closed door. Your freezer obviously has a bad seal. Some frost is inevitable, since you have to open the door to get at your stuff...especially in very humid climates. But excessive frosting is the first sign of an improper door seal.
I though so.
You can access the back of the seals by gently lifting the seal from the inside edge. For the seal that is on the top of your freezer door, it would be the bottom edge of that seal. You can add a strip of 1/4" thick foam weather stripping in beween the door and the seal....and it will push it out just enough to make a better contact with the frame.
I will try that. I am going to get my black tank fixed on Monday and have them look at it.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 01-12-2008, 07:22 AM   #44
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 35
Did you get an answer to this question from them?
Originally Posted by pmclemore
Lewster,
How come my beer supply disappears from my Dometic fridge faster than it does for a similar period at home?
Pat
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 01-12-2008, 04:18 PM   #45
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Absolutely!
But I can't post it on the Forum!!! Then then fell on the floor laughing.
Ya had to be there.........................................:bro ws:
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 01-14-2008, 10:46 AM   #46
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Well, I guess it's ok for them to laugh, as long as they don't point. I hate when they do that.
Pat
pmclemore is offline   Reply With Quote
[IMG] code is Off
Pingbacks are On
New Dometic or Not?? sequoiacoast Refrigerators 24 02-16-2006 08:51 PM
Dometic doesn't cut on ipso_facto Refrigerators 5 11-28-2004 06:55 PM
Dometic Questions balrgn Refrigerators 5 11-09-2004 10:58 PM
Dometic refrig trio Refrigerators 2 08-12-2003 05:11 AM
Dometic woes rdm Refrigerators 4 06-17-2003 06:30 AM
SEO by vBSEO 3.1.0
