Old 01-31-2016, 11:21 AM   #1
Indianapolis , Indiana
AC/Heat Replacement
Hello,
My husband and I own a 1979 Airstream Excella 500. The furnace and ac unit no longer work. We are considering replacing with the Dometic Penguin II heat pump: http://airstreamsupply.com/New-Airst...roduct_id=2329
Questions:
1. How can we confirm this products compatibility with our make/year?
2. Any reason to avoid dual units (heat +ac)?
3. Any better options recommended?
Thanks!
cdauw is offline   Reply With Quote
Old 02-10-2016, 09:13 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Well, your furnace runs on 12 volts, so it will keep you warm without being plugged in to 120 volts. With just a heat pump, you can only keep warm while connected.
If the a/c unit you have now is orignal, those Armstrongs are good units, and worth fixing. (IMHO)
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
