Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 01-21-2008, 11:02 AM   #1
Profile:
68 Bowen HW Heater inlet problem
HI all.
In replumbing my 1968 Overlander, I tried to remove the old flair fittings that were on the water heater so I could update them to new fittings. One came off just fine, but the other broke off just before the tank. It is a 10g heater... looks like a compressed full size house tank. Any ideas as to if I can fix this?
Can I take off that outer shroud to get to the actual tank?
Thanks.
ID:	52933  Click image for larger version
jyobp is offline   Reply With Quote
Old 01-21-2008, 11:21 AM   #2
goransons's Avatar
Profile:  1969 25' Tradewind
Yakima , Washington
we just replaced our water heater on our 69. We're replacing all the pipe too, and new tank etc. After seeing what was inside our tank from 40 years of water I wouldn't reuse it. Can only assume that if that pipe is that bad, that the inside of the tank can't be far behind. Hardest part is getting the old unit out, which it looks like you've already done. I'd call Palomino parts and see about a price to replace the entire thing. 10 Gallon Suburban w/direct ignition was like 250 bucks.
goransons is offline   Reply With Quote
[IMG] code is Off
Pingbacks are On
Bowen water heater John Greenlee Water Heaters, Filters & Pumps 8 05-20-2007 06:21 AM
Bowen Water Heater gduff Member Introductions 1 08-05-2006 11:23 AM
New Atwood water heater old Bowen door vent problem 63air Electrical - Systems, Generators, Batteries & Solar 0 08-22-2005 02:56 PM
Bowen Water Heater 61BambiCanada Water Heaters, Filters & Pumps 2 08-14-2004 07:00 PM
Bowen water heater problem, anyone know what to look at? Silverfly Water Heaters, Filters & Pumps 4 05-04-2004 10:56 AM
SEO by vBSEO 3.1.0
