Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 09-11-2016, 02:50 PM   #1
1966 17' Caravel
Davis , California
66 Caravel black water dump valve???
I have a new to me Caravel and am trying to figure out the systems. I have the original owner's manual which says that the black water dump valve is underneath an exterior cap. Got down there, took the cap off - slowly! - and there's is a beige plastic panel. No obvious way to move it. Would appreciate any help - what I am supposed to be looking for, if there is something I should be installing, anything to let the sewer flow! Thanks so much from a newbie.
nwbiggart is offline   Reply With Quote
Old 09-11-2016, 04:30 PM   #2
68Streamline's Avatar
Cerritos , California
There is a pull lever inside the bumper. You'll see it as you open the bumper cover.
68Streamline is offline   Reply With Quote
Old 09-11-2016, 07:51 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Hi from Colorado and welcome to Air Forums and the vintage Airstream hobby. There is a lot to learn, and these Forums sure helped me learn.
Maybe your 66 Caravel is like my 66 Trade Wind. Your owner's manual probably talks about the gopher hole waste dump method. That isn't done any more!
Your trailer, if like mine, has a rather inadequate black water tank under the toilet. In fact, the toilet is rather inadequate also. Mine was leaking and thus rotted out the plywood floor under the toilet. And the sewer hose connection process involved getting on your hands and knees, opening the hatch, fishing the hose through, connecting it, and then opening the dump valve. Very unhandy in my view.
And you may find that your black water dump valve is likely shot too. At least mine was. They are 50 year old trailers for goodness sakes.
Here is a photo of the black water tank and dump valve. The tank is so thin it is very likely to clog up. I ended up replacing mine and rebuilding the entire bathroom.
David
Name:	1311 Tank Black Removed.jpg
Old 09-11-2016, 08:39 PM   #4
1966 17' Caravel
Davis , California
Thanks to you and 68streamline I have figured it out! My bumper box was upgraded and while quite nice it hid the valve pull. Now I know where it is
Yes, these are old babies and need a bit of care. Had a number of repairs but if this tank doesn't cooperate its next on the list.
Old 09-11-2016, 08:49 PM   #5
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Nwbiggart
If you check the vintage Airstream site, in the resources section Colin Hyde has direction for converting your dump valve to modern system. I converted ours and it works great.
Tim
Beaker63 is offline   Reply With Quote
Old 03-15-2017, 10:26 PM   #6
1967 17' Caravel
La Mesa , California
we have been trying to figure out how to dump the tank for a year! (Gross, I know, but we thought it was bad plumbing or something. We had no idea that the bumper opened! Yay! What a relief! Thank you!!!
d-na is offline   Reply With Quote
caravel
Black water dump valve push pull rod missing firetech51 Waste Systems, Tanks & Totes 2 08-26-2009 08:44 PM
Black Water Dump Valve SJ Brown Waste Systems, Tanks & Totes 2 06-17-2009 07:24 PM
Black water Dump valve Cautions r.baker43 LP Gas, Piping, Tanks & Regulators 4 01-23-2006 07:25 PM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
