Old 10-07-2011, 05:26 PM   #15
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Thanks for Checking
I'm pretty sure the Fantastic Fan on my 2000 worked just as you described, withidl. That's why I was so surprised when the vent cover motor ran with the fan switch in the "off" position. So, I just dug out the instruction sheet. It says, "When sensor becomes wet, dome will close automatically and shut off fan blade, if it is on." This wording seems to imply that it will also close automatically if fan is off, as happened to me. My FF is a Model 6000A. The instructions were printed 04-04.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-07-2011, 05:30 PM   #16
Baltimore , Maryland
how does the rain sensor sense to close for rain if it already closed? That part does not make sense here...
if you want the rain sensor to work when the fan is off, turn it off by adjusting the thermostat. If it is too hot to turn on, the fan will not run but the sensor will close the lid when it rains.
Old 10-07-2011, 05:37 PM   #17
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Fantastic 101
Just for quick future reference:
If you want your rain sensor to close the lid, but have the fan not run, put the motor control in "1", and the air switch in "neutral", between "in" and "out".
If you want the vent open or closed, no matter what, open the vent, and turn the motor switch to "0".
For factory-installed Fantastics, to make sure everything is off, make sure the fan motor is at "0", and the fan switch is "off".
Old 10-07-2011, 06:55 PM   #18
withidl's Avatar
2002 31' Classic
Houston , Texas
If It Had Been A Snake..........
I'd have been bitten! I remember using the "air switch" NEUTRAL position several years back but had forgotten it was there. Thanks for pointing it out (I need to write that down so as not to forget it again).
withidl is offline   Reply With Quote
Old 10-07-2011, 08:16 PM   #19
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Ah, but the newer fans don't have an In-Off-Out switch. It has been replaced by a simple On-Off switch as the factory installed fans only exhaust. I miss that feature that allows them to pull in fresh air. Turning the thermostat to warmer or turning the fan speed to 0 kills the fan but not the lid motor. I believe the On-Off switch should kill both but I haven't verified that.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 10-08-2011, 08:12 AM   #20
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Nope
The "On-Off" switch does not kill them both. That's what this thread is all about. The Fantastic Fan is wired to close the vent cover when it rains even when the "On-Off" switch is "Off."
Ken L
1966 Tradewind 24
Old 10-08-2011, 08:33 AM   #21
Well Preserved
1993 21' Sovereign
Exactly. Also, if you want the reversing switch, all you have to do is call Fantastic, and they'll happily send you one for a small fee, with installation instructions. IIRC, the last one I bought was maybe $15, delivered to my door.
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Bad Batteries? Nightwatch Electrical - Systems, Generators, Batteries & Solar 8 05-23-2011 01:58 PM
New Batteries - 6V vs. 12V Wolfie Batteries, Univolts, Converters & Inverters 7 05-07-2011 02:13 PM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
