Old 09-11-2011, 10:37 AM   #1
Images: 18
Yay! 50 amp Service upgrade - Done
It was a challenge but we successfully upgraded to a 50 amp service with 8 breakers. Took us about 4 hours but we are ready for the 2nd AC; just in time for the temp to drop soon. If anyone needs an airstream 30 amp cable it's available.
yve79 is offline   Reply With Quote
Old 09-12-2011, 05:17 AM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'd add another end and make it an extension cord for those times when I need an extension cord but don't need 50 amp service.
Congratulations on the conversion!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-12-2011, 09:15 AM   #3
Images: 18
No clue what your talking about but I will pass the suggestion on to the husband and see what he thinks.
Thanks for the reply!
Old 10-25-2012, 09:32 AM   #4
Images: 18
Diagram for 50 amp conversion.
Old 10-25-2012, 09:37 AM   #5
Images: 59
You need to break apart the ground and neutral. As shown in your diagram it is unsafe.
Old 10-25-2012, 09:40 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I noticed that you tied neutral to ground inside the breaker box. On a 30amp system these two are isolated from each other on separate buses. I think it should be the same on 50amp service also, but I am not an electrical.
Richard
Old 10-25-2012, 10:34 AM   #7
lewster's Avatar
Naples, FL , Hood River, OR
ABSOLUTELY!!!!
The ground and neutral should be on separate bus bars, NOT tied together for any RV installation. Your installation as posted is a recipe for disaster or worse.
I WOULD CORRECT THIS IMMEDIATELY AND NOT PLUG IN THE TRAILER TO YOUR POWER SOURCE UNTIL IT IS FIXED PROPERLY
Old 10-25-2012, 10:59 AM   #8
Images: 59
Also, the plug or receptacle you show is for 30amp 120/240vac, not 50amp service. And if it was the correct recptacle you have the ground and neutral reversed. Please hire an electrician before something bad happens.
Old 10-25-2012, 11:13 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I haven't used a 50 amp service at a campground, but I think you will find that only half of your panel will be hot. Since I believe it is wired thru a single breaker and not a double pole breaker, which is typically how the 240 volt wiring is done in your home.
The neutral and ground should not be connected together. The neutral should not be bonded to the trailer body. Only the ground should be bonded to the trailer body.
Old 10-25-2012, 11:33 AM   #10
Images: 59
TG,
Not true. Both legs are hot and feed through a 2 pole breaker.
Old 10-25-2012, 11:38 AM   #11
Images: 18
If that scares you I guess you shouldn't look ten feet away at your service where the ground and neutral are always tied together. In small electrical boxes they generally are not available with a separate ground and neutral bar. FYI, you're no safer with the ground and neutral (aka a grounded conductor) separated. All your signal lights are using your trailer frame as the ground.
Old 10-25-2012, 11:40 AM   #12
Images: 59
You don't understand the basics of electrical safety. Please stop before you burn down your trailer.
Also, you should have bought a box with mains breakers, not a mains lug box. You are in way over your head.
Old 10-25-2012, 11:46 AM   #13
Images: 18
Why would I need two breakers? There is a 50 amp breaker right outside. The original box that I replaced did not have a main breaker either.
Old 10-25-2012, 11:51 AM   #14
Images: 59
The original box probably had a main breaker, you just didn't notice that it was backfed from the inlet.
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
2008 Airstream Classic 31! 50 Amp Service, 2 AC Units! eBay Watch Airstreams on eBay 0 08-30-2011 08:20 PM
3 Amp Availability gaylejoe WBCCI Forum 27 08-06-2011 03:38 PM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
