Old 09-28-2010, 01:39 PM   #1
2005 30' Classic S/O
Annandale , New Jersey
Yamaha EF3000iSE 3,000 Watt
Hi
Just bought a 2005 30' Classic SO. Starting the process for first newbie pull.
Question #1: will a Yamaha 3000 suffice for electrical coverage or do you need two Yamaha 2000 inverters instead??
Question #2: if you want to run AC as well as TV, etc, are two inverters a better approach?
David
DL46 is offline   Reply With Quote
Old 09-28-2010, 02:58 PM   #2
Mantua , Ohio
The 3000 should run one ac ok. jim
Old 09-28-2010, 03:16 PM   #3
dstalzer's Avatar
2005 25' Classic
My Yamaha 2400iS inverter runs the 15000 btu A/C by itself with no problem, so I would think the Yamaha 3000 would handle the A/C and TV. Do not try to run the microwave while the A/C is running, but either one by itself is ok.
Dennis
dstalzer is offline   Reply With Quote
Anyone here own EF3000ISE in the UK weloveraw Generators & Solar Power 0 01-12-2010 06:19 AM
Kill A Watt AC power use firefly007 Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-04-2006 07:50 PM
10 watt halogen bulbs Foiled Again Off Topic Forum 13 01-12-2006 06:54 AM
28,000 or 128,000 miles? jimelmoreiii Mechanics Corner - Engines, Transmission & More... 8 01-11-2004 07:16 AM
Kill A WATT™ 53flyingcloud Our Community 6 06-20-2003 12:08 PM
