Old 03-01-2012, 06:31 PM   #1
1974 25' Tradewind
Berryville , Virginia
Question wiring? Univolt to Converter '74 Tradewind
I have converted from the old univolt to a new 45 amp converter. I am now wiring to the converter. Is the Blue wire form the car battery wired to the positive side of the DC battery terminal ?
I then have 3 wires which run to the control center red , black and gray. red and black have line fuses.Are these supply wires to the control center? Are they simply now wired into the new DC converter side as circuits with the two line fuses cut and tied into the new fused converter block?
batt is offline   Reply With Quote
Old 03-01-2012, 06:46 PM   #2
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
I changed to a new converter a couple months ago. I will take a look tomorrow to see exactly what I did. This CRS stuff is getting worse all the time.
Flynavy is offline   Reply With Quote
Old 03-02-2012, 09:21 AM   #3
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
I replaced the univolt with a 45amp converter and a fuse panel.
Coach bat. pos. goes into a 50 amp. fuse then into DC pos. imput on fuse panel.
Coach bat. neg. goes into ground terminal bus on fuse panel.
Car bat. charge line (blue wire) goes to DC pos. imput on fuse panel.
I ran a red wire from DC pos. imput on fuse panel to converter pos. lug.
Also ran a black wire from ground panel to converter neg. lug.
I installed a duplex 110vac. receptical to plug converter into.
I think the wires that run to the controll center are for the centers power-on-light and the ammeter. I did not use these so I no longer have those functions on my control center. There is a way to get the ammeter working again but if I remember right it was fairly expensive to do so I let it go. As far as I know there is no way to get the power-on-light working.
Hope this helps.
Old 03-02-2012, 09:37 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Hope this helps.
I am not sure that the blue wire (car battery +) should be connected as an input line. On the original fuse panel it was connected as the output for circuit #5 and protected with a 40 amp fuse.
The new converters do not have an independent 12+ line for the power on light. Some members have used a small 12 volt plug in (120 volt) transformer to power the light. I have not done this since I have a phase detector and volt meter plugged in.
ID:	152360   Click image for larger version
Richard
Old 03-03-2012, 02:53 PM   #5
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
If you are correct than I have mine wired incorrectly. Here is the what I used.
Name:	converter diagram.jpg
Old 03-03-2012, 05:18 PM   #6
1974 25' Tradewind
ok, I am no wiring wiz , here are some questions. Where do I tie the car white ground wire into? Do I hook into the lug on the 12v side or to the ground on the 120 side where I have the frame #6 ground tied, or does it matter?
Still confused on the Blue car pos + wire as to where it is meant to go.Manual has it running from the car and tied to 12v side as circuit #5 which seems to run to the control center only and power nothing.
From what I have read the control panel ammeter was a bit of a joke and really told you little of the battery condition. At present I would like to have it work simply to see the holding tank levels. Can any one address these issues.
Old 03-04-2012, 11:13 AM   #7
1974 25' Tradewind
I believe you are correct that #5 Blue from car was wired into the fuse panel .Since I am rewiring and have nothing to go by I looked at your schematic and wondered how you grounded the neg terminal to the body. I drilled and grounded a # 6 solid copper wire to the frame and ran it up into the ground bridge on the 120 side . Should I also run ground to the battery neg cable?. Where do the vehicle white ground tie in, on the ground bridge on the 120 side or on the low voltage side or does it even matter?
Old 03-04-2012, 11:36 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Don't run the ground/common wire into the 120 volt panel. Just attach it to the skin in a convenient place. On my '74 Argosy the blue wire is the charge line. Connect it to the positive side of the system, it should have at least a 30 amp fuse in series with the connection.
Old 03-04-2012, 12:46 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, the blue wire needs to be on the + side, otherwise it wouldn't charge the battery.
The puzzling thing I recently found is that I have 2 heavy gauge white wires in the wiring bundle. One was connected to the univolt negative load, the other was screwed to the skin. I'm thinking that they must connect somewhere in the harness (?).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-04-2012, 01:09 PM   #10
Ottawa , ON
All the 12V stuff I have come across in my TT uses + only wiring, ground is always the skin.
Old 03-04-2012, 01:41 PM   #11
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
I believe the control panel is on one of the 12 vdc. branch circuits. Your new converter/fuse panel will power up the holding tank level indicaters and the waterpump. The ammeter and power on light will not function. I also read the ammeter was basicly useless.
Twinkie and Chuck state that having the blue car batt. charge line as I have done is correct.
The 12vdc neg. was grounded to the skin near the old univolt location. I did not make any changes. I did relocate the 110vac circuit panel closer to the closet door just for better access. I only moved it as far as the slack in the wire would allow. It is a lot easier to get to now.
I bought the new converter/fuse panel from Best Converter. I will e-mail Randy and ask him to look at this thread just to be sure.
Old 03-04-2012, 02:05 PM   #12
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Look at Richard's pic above; there's a big-ol' white wire attached to the right of the ammeter shunt; that's marked "negative load" in the diagram.
(mine has another one of those white wires, of the same gauge, that comes out of the hole in the skin, along with the rest of those wires...but is just attached to the skin.)
Air:291
Wbcci: 3752
'73 Safari 23'
Old 03-04-2012, 03:33 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have yours wired like that in the drawing above and have the 55 amp circuit breaker in series with the battery positive then you are OK. The circuit breaker provides protection just as the fuse would.
Old 03-05-2012, 07:58 AM   #14
1974 25' Tradewind
Ok, On my trailer ,I had a #6 coppr ground wire which was fastened to the main I frame and was the main ground, I know this because I had to do major frame repair.Perhaps this was a later addition?
The two white wires are the ground wire from the car wiring and also runs to the radio console as a ground there. I noticed that one had a screw fastener on it, so I am guessing that this would ground to the body. The other would ground on the ground strip on the converter on the position where the battery ground ties in? Please verify.
Now just to clarify the blue wire is a circuit and wired into one of the fused circuits on the 12v side, correct?Since mine has two 30amp circuits on lines 1 an 2 it would have to be one of these.
The red and black lines are 12v circuit lines for the holding tanks and power the indicators on the control tank console? These are to become individual fused circuits on the 12v side. They also have line fuses I am guessing that now they are on a fused panel circuit they will not need the line fuse?
The gray wire is the ammeter power source which for some reason will not now function if I were to hook it to the 12v circuit, since it is now redundant with the new converter?
Sorry for being anal about this , I just want a minimum frustration level at power up time.
Thanks for everyone's time I am talented at a lot of things , not wiring.
Converter Conundrum benyeomans Batteries, Univolts, Converters & Inverters 15 07-29-2011 02:56 PM
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 10:27 PM
F-150 torque converter lock-up woes... Dave Park Tow Vehicles 30 06-09-2011 08:27 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
