Old 04-19-2014, 07:58 AM   #29
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
univolt replacement
I am trying to hook up a new progressive dynamics intellipower 9245 using the old univolt fuse block on my 1972 Ambassador.
I am LOST.....
Does anyone have a clear diagram on how to hook this thing up ?
thank you !
1972 Ambassador Itn'l 29'.Custom Interior
1987 Avion 34X
1985 Avion 30R
Airline is offline   Reply With Quote
Old 04-21-2014, 12:31 PM   #30
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you removed the original Univolt, you would have disconnected it from the fuse panel. The 9245 should connect in the same manner.
Post a pic of your fuse panel. We will try to help.
I would recommend upgrading the fuse panel. To the newer style. No more dealing with the glass fuses and poor connections.
Old 04-21-2014, 02:12 PM   #31
Airline's Avatar
1972 29' Ambassador
Heres What I have so far:
changed the 30A neg battery fuse to a 40
What do you think ? Will it work ?
thanks !
Mark
1987 Avion 34X
1985 Avion 30R
Old 05-10-2014, 11:06 AM   #32
Salida , Colorado
Is there any reason not to wire the converter to the back of the fuse panel using the nuts. Instead of the connecting blocks your using?Click image for larger version
Name:	airstream fuse panel.jpg
Moonhill is offline   Reply With Quote
Converter Conundrum benyeomans Batteries, Univolts, Converters & Inverters 15 07-29-2011 02:56 PM
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 10:27 PM
F-150 torque converter lock-up woes... Dave Park Tow Vehicles 30 06-09-2011 08:27 AM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
